查看: 94|回复: 1
[结构] 预应力混凝土中的预应力钢筋过度扭曲,怎样处理?
发表于 2011-10-15 16:26:37 | 显示全部楼层 |阅读模式 来自 山东青岛
S T R E S S    C A L C U L A T I O N S
Over-distorted element, DET= 0.0000000E+00  GROUP=      3  ELEMENT=      5941
Over-distorted element, DET= 0.0000000E+00  GROUP=      3  ELEMENT=      6122
Over-distorted element, DET= 0.0000000E+00  GROUP=      3  ELEMENT=      6303
THERE IS A TOTAL OF      184  OVER-DISTORTED ELEMENTS. THE DISTORTION MIGHT BE
DUE TO EXCESSIVE STRAINS (IF LARGE DISPLACEMENT/SMALL STRAIN FORMULATION IS
USED) OR SLIVER ELEMENTS IN THE ORIGINAL MESH.
          NO NONZERO REACTIONS PRESENT
                    ** WARNING NO. A6   **
Element distorted, Jacobian DET=  0.00000000E+00  GROUP=      3  EL=      5941
** ERROR NO. A1101 **
Mesh too distorted, Jacobian determinant not positive
  S O L U T I O N   T I M E   L O G (IN SEC)
            FOR PROBLEM
这是出来的文件,怎样去处理呢
发表于 2011-10-15 17:23:45 | 显示全部楼层 来自 江苏苏州
建议你把你的问题好好叙述呢_不然没法回答呢
GMT+8, 2024-11-1 23:37 , Processed in 0.026524 second(s), 11 queries , Gzip On, MemCache On.
