查看: 116|回复: 1
[RADIOSS Bulk] 求大侠指点:汽车部件在HM里点焊装配,然后倒入HC的问题
发表于 2011-11-18 10:32:57 | 显示全部楼层 |阅读模式 来自 江苏南京
在HM里怎么样用SPOTWELD把汽车各个部件点焊装配起来,然后再倒进HC里做碰撞仿真。求各位大侠指点!!!
发表于 2011-11-26 13:07:29 | 显示全部楼层 来自 美国
if you have the spotweld file or the xml. you can realize them in the HM by select TYPE2.
in HC you can get the right propetiry for the spot welds 1Ds. always simulated by /PROP/TYPE13 springs.
hope it can help you. may be your question is very easy if you learn the HM manual.
GMT+8, 2024-11-1 15:29 , Processed in 0.026694 second(s), 10 queries , Gzip On, MemCache On.
