查看: 48|回复: 0
[前后处理] 计算时只出现log window,没有计算窗口的原因?
发表于 2012-7-9 08:23:37 | 显示全部楼层 |阅读模式 来自 上海
进行计算,结果计算没有进行,只弹出log window,提示如下:
ADINA data input file F:\别碰我!\!\16.dat successfully created.
***WARNING: The automatic time-stepping method will not be used in linear analysis.
             No element connection for node 1 directions 1, 4, 5, 6
             No element connection for node 2 directions 1, 4, 5, 6
             No element connection for node 3 directions 1, 4, 5, 6
             No element connection for node 4 directions 1, 4, 5, 6
             No element connection for node 5 directions 1, 4, 5, 6
             No element connection for node 6 directions 1, 4, 5, 6
             No element connection for node 7 directions 1, 4, 5, 6
             No element connection for node 8 directions 1, 4, 5, 6
             No element connection for node 9 directions 1, 4, 5, 6
             No element connection for node 10 directions 1, 4, 5, 6
             No element connection for node 11 directions 1, 4, 5, 6
             No element connection for node 12 directions 1, 4, 5, 6
             No element connection for node 13 directions 1, 4, 5, 6
             No element connection for node 14 directions 1, 4, 5, 6
             No element connection for node 15 directions 1, 4, 5, 6
             No element connection for node 16 directions 1, 4, 5, 6
             No element connection for node 17 directions 1, 4, 5, 6
             No element connection for node 18 directions 1, 4, 5, 6
             No element connection for node 19 directions 1, 4, 5, 6
             No element connection for node 20 directions 1, 4, 5, 6
             No element connection for node 21 directions 1, 4, 5, 6
             No element connection for node 22 directions 1, 4, 5, 6
             No element connection for node 23 directions 1, 4, 5, 6
             No element connection for node 24 directions 1, 4, 5, 6
             No element connection for node 25 directions 1, 4, 5, 6
             No element connection for node 26 directions 1, 4, 5, 6
             No element connection for node 27 directions 1, 4, 5, 6
             No element connection for node 28 directions 1, 4, 5, 6
             No element connection for node 29 directions 1, 4, 5, 6
             No element connection for node 30 directions 1, 4, 5, 6
             No element connection for node 31 directions 1, 4, 5, 6
             No element connection for node 32 directions 1, 4, 5, 6
             No element connection for node 33 directions 1, 4, 5, 6
             No element connection for node 34 directions 1, 4, 5, 6
             No element connection for node 35 directions 1, 4, 5, 6
             No element connection for node 36 directions 1, 4, 5, 6
             No element connection for node 37 directions 1, 4, 5, 6
             No element connection for node 38 directions 1, 4, 5, 6
             No element connection for node 39 directions 1, 4, 5, 6
             No element connection for node 40 directions 1, 4, 5, 6
             No element connection for node 41 directions 1, 4, 5, 6
             No element connection for node 42 directions 1, 4, 5, 6
             No element connection for node 43 directions 1, 4, 5, 6
             No element connection for node 44 directions 1, 4, 5, 6
             No element connection for node 45 directions 1, 4, 5, 6
             No element connection for node 46 directions 1, 4, 5, 6
             No element connection for node 47 directions 1, 4, 5, 6
             No element connection for node 48 directions 1, 4, 5, 6
             No element connection for node 49 directions 1, 4, 5, 6
             No element connection for node 50 directions 1, 4, 5, 6
             Message limit reached - above message has been suppressed 137 times.
             Nodal degrees of freedom without element
             connection have been fixed for data input file.
             There may still be degrees of freedom without
             stiffness - see documentation.
out文件已上传
GMT+8, 2024-11-1 21:37 , Processed in 0.029424 second(s), 10 queries , Gzip On, MemCache On.
