查看: 285|回复: 10
[RADIOSS Bulk] 这个问题困扰了一天了求解决啊
发表于 2012-7-14 15:03:27 | 显示全部楼层 |阅读模式 来自 江苏镇江
在radioss里面做静力分析总是出现这种错误提示:材料属性
都已经设置好了(图片是材料属性的设置)
**                          OptiStruct 10.0                           **
**                  Design and Optimization Software                  **
**                   from Altair Engineering, Inc.                    **
**               Professional  SP1 (Build 7601)  RZN-PC               **
**        2 CPU:  Intel(R) Core(TM)2 Duo CPU  P7350  @ 2.00GHz        **
**                        CPU speed  2000 MHz                         **
**                     932 MB RAM,  4085 MB swap                      **
** Build tag: 0466938_5333O00_Ci3242M-000      14000                  **
**  COPYRIGHT (C) 1996-2009                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc.                 **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: D:\Altair\hw10.0/hwsolvers/hwsolver.cfg
*** ERROR # 1237 ***
CSHEAR element number 25873 references
        a missing or invalid property number 4.
CSHEAR element number 25874 references
CSHEAR element number 25875 references
CSHEAR element number 25876 references
CSHEAR element number 25877 references
CSHEAR element number 25878 references
CSHEAR element number 25879 references
CSHEAR element number 25880 references
CSHEAR element number 25881 references
CSHEAR element number 25882 references
CSHEAR element number 25883 references
CSHEAR element number 25884 references
CSHEAR element number 25885 references
CSHEAR element number 25886 references
CSHEAR element number 25887 references
CSHEAR element number 25888 references
CSHEAR element number 25889 references
CSHEAR element number 25890 references
CSHEAR element number 25891 references
*** More of ERROR messages # 1237 were suppressed...
Too many error messages. Aborting run.
Current limit is 10000. Use "MSGLMT" control card to change this value.
Following error/warning messages appeared too many times
and were suppressed:
    1237
Total of 9980 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
 楼主| 发表于 2012-7-14 16:36:03 | 显示全部楼层 来自 江苏镇江
求高手解答啊!模型附件
发表于 2012-7-16 09:33:17 | 显示全部楼层 来自 江苏苏州
应该是属性定义有问题
发表于 2012-7-17 16:08:34 | 显示全部楼层 来自 江苏扬州
求几何模型,改了属性还是不行,坐等高手。。。加我秋秋:270928052 共同商讨如何解决
发表于 2012-7-17 18:36:57 | 显示全部楼层 来自 江苏泰州
MSGLMT 这个卡片是控制你的错误,警告,信息的数量的.默认的是1000,修改一下这个卡片的值看看
发表于 2012-7-18 08:17:28 | 显示全部楼层 来自 江苏扬州
lowelljiayou 发表于 2012-7-17 18:36
MSGLMT 这个卡片是控制你的错误,警告,信息的数量的.默认的是1000,修改一下这个卡片的值看看 ...
翻译谁都会啊。。
发表于 2012-7-18 18:50:23 | 显示全部楼层 来自 江苏无锡
属性设置错误,楼主改下属性看看
 楼主| 发表于 2012-7-27 13:30:30 | 显示全部楼层 来自 江苏镇江
是不是单元类型没有定义呢 我最后在elem type里面update一下就没有上面的问题了!
发表于 2012-8-29 11:43:26 | 显示全部楼层 来自 湖北十堰
你设置的可能是3d单元网格的属性,但你的网格是2D的就会出现这种错误,请把2d网格删除就好了
发表于 2012-8-29 20:01:19 | 显示全部楼层 来自 江苏无锡
你的属性问题已经帮你解决,但是weld连接也要改,建议每个weld重新建立,或者改用rigid body
发表于 2012-10-30 19:48:23 | 显示全部楼层 来自 福建福州
可以去看看OUT里面的具体提示
GMT+8, 2024-11-1 15:25 , Processed in 0.041131 second(s), 12 queries , Gzip On, MemCache On.
