查看: 248|回复: 3
[ADAMS CAR, Chassis, Engine] 整车平顺性仿真
发表于 2012-11-13 16:52:01 | 显示全部楼层 |阅读模式 来自 合肥工业大学
悬赏10仿真币未解决
运行整车脉冲路面仿真时出现仿真错误
Static equilibrium analysis has not been successful.
    The maximum number of iterations 100, has been reached.
    For the last attempted iteration:
    The equation with the largest error was model.testrig.vas_throttle_demand.variable Comp = 0 Error = 1662829.315802
    The variable receiving the largest increment was model.testrig.sse_diff1 Comp = 0 Delta = 1662829.315802.
请各位专家指点~速度30~60km/h都可以,就10、20km/h仿真都出现以上错误
发表于 2013-1-8 17:18:53 | 显示全部楼层 来自 河北秦皇岛
顶一下,现在也在研究平顺性方面的问题。
回复
发表于 2013-1-15 16:00:09 | 显示全部楼层 来自 上海
显示的是静平衡的问题,有可能是挡位设置不对。做低速的时候响应地改小一点挡位试试
回复
发表于 2013-3-5 15:45:18 | 显示全部楼层 来自 辽宁
东西很有用谢了!!!不过可惜没看见二楼的!!
回复
GMT+8, 2024-11-2 21:29 , Processed in 0.028083 second(s), 9 queries , Gzip On, MemCache On.
