查看: 51|回复: 0
[ADAMS CAR, Chassis, Engine] 悬架仿真出错求助
发表于 2013-3-25 22:32:41 | 显示全部楼层 |阅读模式 来自 江苏苏州
参照adams自带的double_wishbone_torsion.tpl,自己重新建了一遍,但在执行suspension subsystem的双轮同向跳动仿真时,出现了如下的错误。请各位帮忙一起研究分析。谢谢!
----WARNING ----
   Actuatorreached lower force limit
   ID = 1
---- WARNING ----
   FIELD test3_parallel_travel.test1_bkl_uca_front_field is violating the assumption ofsmall angles.
   Angle Limit = 0.20, Angles = [ 6.61363E-03,0.21236, -1.1183 ]
---- WARNING ----
   FIELD test3_parallel_travel.test1_bkl_uca_rear_field is violating the assumption ofsmall angles.
   Angle Limit = 0.20, Angles = [ -6.61363E-03,0.21236, 1.1183 ]
---- ERROR ----
   Attempt = 1. No convergence after 25iterations. Best iteration = 11.
   Trying next attempt with a different set ofstatics parameters...
   For the last attempted iteration theequation with the largest error
   was PART test3_parallel_travel.test1_gel_tbar  Error= 2.09607E+07
   The variable receiving the largest increment
   was JOINT test3_parallel_travel.test1_jolfix_tbar_to_subframe  Delta = 6.03055E+07
---- ERROR ----
   Static equilibrium analysis has not beensuccessful.
   Restoring the input initial conditions...
---- ERROR ----
   Static Simulation Not Successful AutoForce Pattern:
   ID = 1
   Terminating ADAMS/Car usersubs...
   ID = 1
      ADAMS/Solver execution terminated bysubprogram ERRMES
   CPU time used = 0.46875 seconds
Analysisfailed!
Pleasecheck the error messages to determine the cause.
GMT+8, 2024-11-2 21:25 , Processed in 0.036914 second(s), 11 queries , Gzip On, MemCache On.
