- 2012-11-2
小弟新手,还请大神指教。
Microsoft Windows [版本 6.1.7600]
版权所有 (c) 2009 Microsoft Corporation。保留所有权利。
F:\Component>"F:/HyperWorks/hwsolvers/bin/win32/radioss.bat" -shell "F:/Componen
t/Mesh assembly.fem" -analysis -optskip
WARNING in hwsolver script execution:
Found only 32-bit HyperWorks solvers and this is 64-bit host
Found config file: F:\HyperWorks/hwsolvers/hwsolver.cfg.
Preserving existing .out file as:
F:/Component/Mesh assembly_011.out
Preserving existing .stat file as:
F:/Component/Mesh assembly_011.stat
** RADIOSS 11.0 **
** Finite Element Analysis Software **
** from Altair Engineering, Inc. **
** Windows 7 Workstation (Build 7600) WIN-0QPHHTQQN2T **
** 2 CPU: Intel(R) Pentium(R) CPU G630 @ 2.70GHz **
** CPU speed 2700 MHz **
** 1623 MB RAM, 4095 MB swap **
** Build tag: 0563690_5333110_Ci32RH11M:59910-000 14000 **
** COPYRIGHT (C) 1996-2011 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
Too many error messages. Aborting run.
Current limit is 10000. Use "MSGLMT" control card to change this value.
Errors reported during program execution
Error output from the solver:
Activating OPT SKIP mode.
hwsolver.mesg output from the solver:
Detected while reading line 196951 from file F:/Component/Mesh assembly.fem:
"CTETRA 112805 0 119912 95594 95766 95768"
Solver FAILED
optistruct:: Solver run finished.
F:\Component>
F:\Component> |
