某车前悬,双轮同向跳动仿真不成功。。 下面有很多说marker点说不存在,是什么个情况?? 这些marker点是自己建request的时候用到的,明明都在的啊
Reading in property files... Reading of property files completed. Setting up assembly for analysis ofloadcase: 'parallel_travel'... Writing analysis information toAdams/Solver command file: 'test_parallel_travel'. Simulation(s) are beginning...
********************************************************************* * * * MSC.Software Corporation * * * * A da m s * * * * Automatic DynamicAnalysis of Mechanical Systems * * * * A d a m s /S o l v e r * * (Build:2011.1.0-CL98828) * * * * 2013-03-31 10:17:27 Version MD 2011 * * * * Customer EntitlementID: 9EC641EE-BB3EE3BB * * * *********************************************************************
Enter ADAMS model file name or CarriageReturn or ? (or STOP):
Nomodel input file (ADM file) is given.
Enter Command:
file/model=test_parallel_travel
Anew model supplied. Initializationstarts...
The default input and analysis values will be restored.
CPU time used = 0.39062 seconds
Enter ADAMS output file name or ?(default is same as input):
Adams model file .. test_parallel_travel.adm
Default file names for output files
Tabular output file: test_parallel_travel.out
Diagnostic file : test_parallel_travel.msg
Message Database file : test_parallel_travel.mdb
Graphics file : test_parallel_travel.gra
Request file : test_parallel_travel.req
Results file : test_parallel_travel.res
Input Phase - Reading in Model
*********************************************************** Adams/Solver dataset Title: Adams/Car Assembly (MD Adams 2011) ***********************************************************
ERROR: The MARKER referenced by ID number does not exist. ERROR: Value : 163 ERROR: Argument : I ERROR: Statement : REQUEST/122 ERROR: Line number : 4377
ERROR: The MARKER referenced by ID number does not exist. ERROR: Value : 240 ERROR: Argument : J ERROR: Statement : REQUEST/122 ERROR: Line number : 4377
ERROR: The MARKER referenced by ID number does not exist. ERROR: Value : 162 ERROR: Argument : I ERROR: Statement : REQUEST/123 ERROR: Line number : 4389
ERROR: The MARKER referenced by ID number does not exist. ERROR: Value : 238 ERROR: Argument : J ERROR: Statement : REQUEST/123 ERROR: Line number : 4389 ERROR: Errors in the Adams dataset prevent itfrom being loaded into the database.
Reading of model complete.
Adams/CarMD Adams 2011
Processing ENVIRONMENT entries in 'F:\adams_a\acar/acar.cfg' Processing ENVIRONMENT entries in 'C:\Documents andSettings\Administrator/.acar.cfg'
ERROR: There is no corresponding object for this lookup index. ERROR: Error type: ae_lookup_object_index
ERROR: The attribute does not belong to the object. ERROR: Error type: ae_attribute_mismatch ERROR: Object name: ERROR: Object type: ao_null ERROR: Attribute: aa_string_string
OS-environment detected: MDI_CDB_SEARCH=no Adams/Car will restore the cdb search algorithm from version 12.0 (ifset to 'yes'). Usage of this environment variable is strongly discouraged.
OS-environment detected: MSC_MULTILINE_XML=1 Adams/Smartdriver will use multi-line formatting when instantiating xmldriver control files (0 or 1; default=1).
================================================================= Adams/Tire Version MD Adams 2011 =================================================================
Input Phase - Populating Solver database
----ERROR ---- Error(s) found in input, no model available.
Input Phase Complete.
CPU time is 0.3750 seconds.
----ERROR ---- Anerror has been found in the model dataset supplied through the FILE/MODEL command. Dataset file name is: test_parallel_travel.adm
Enter Command:
preferences/solver=F77
Enter Command:
control/ routine=acarSDM::con950,function=user(950,29,31,1,2,18,20,1,3,2,3,28,30,2,3,28,30,1,1)
----ERROR ---- Nomodel is present in memory at this instant. Read in an Adams/Solver data set first.
Enter Command:
simulate/static, end=21.000000, steps=20
Enter Command:
Enter Command:
stop
Terminating Adams/Car usersubs...
Adams/Solver execution terminated by subprogram A3TERM
CPU time used = 0.3750 seconds Simulation(s) are complete! Loading analysis results... ERROR: Cannot load results! File 'test_parallel_travel.res' not found. Loading results done.
