查看: 54|回复: 1
[ADAMS CAR, Chassis, Engine] 整车装配出现点问题,求助下各位
发表于 2013-6-4 17:02:49 | 显示全部楼层 |阅读模式 来自 河南郑州
WARNING: The following input communicators were not assigned during assembly:
     testrig.cis_max_brake_value
     testrig.cis_downforce_coefficient
     testrig.cis_crankshaft_ratio
     testrig.cis_transmission_efficiency
     testrig.cis_drive_torque_bias_front
     zy_liang_front_sus.cil_ARB_pickup
     zy_liang_front_sus.cir_ARB_pickup
WARNING: The following input communicators did not match with unique output communicators:
     zy_powertrain.cil_tire_force
        matched with:  zy_liang_front_tire.col_tire_force
        also matches:  zy_liang_rear_tire.col_tire_force
     zy_powertrain.cir_tire_force
        matched with:  zy_liang_front_tire.cor_tire_force
        also matches:  zy_liang_rear_tire.cor_tire_force
发表于 2013-6-8 10:52:33 | 显示全部楼层 来自 湖南长沙
上面是有的通讯器没连上
下面是有的输入通讯器匹配了不止一个输出通讯器
下面的必须去模型里修改通讯器。。。
我的是把下面的修改没以后,上面的没管,   能动了
GMT+8, 2024-11-2 17:29 , Processed in 0.028744 second(s), 11 queries , Gzip On, MemCache On.
