查看: 177|回复: 1
[Flex及相关] 柔性体仿真出错~~
发表于 2013-7-15 11:57:00 | 显示全部楼层 |阅读模式 来自 山西太原
ERROR:   Time 4.512907E+00:
Acceleration computation failed to converge after 25 iterations.
Equation with the largest imbalance: Vfo/Frict/1 Z Force
Imbalance = 8.267584335E+05
Variable receiving largest increment: Part/3 X Acc
Delta = 0.000000000E+00
1) Check mass and inertia properties to ensure they are valid.
2) Make sure the choice of units is appropriate for the system. Systems that have very small inertias may benefit from "small" force units, e.g., dynes.
3) Check that motion generators are valid and no redundant constraints exist.
4) Check if impact functions caused a strange response in the model (verify properties).
5) An IMPLICIT DIFF element which does not reference DIF1 must be satisfied by its IC.
ERROR:   Lockup detected
发表于 2013-7-15 13:05:01 | 显示全部楼层 来自 清华大学
看看 后处理变形情况吧
GMT+8, 2024-11-2 17:36 , Processed in 0.032476 second(s), 11 queries , Gzip On, MemCache On.
