- 2013-5-10
我在ANSYS里建了个柔性体模型,生成MNF文件导入到ADAMS中,加了约束后不能计算,我是一个屋盖模型,在十二个柱脚处加了十二个固定约束,看错误提醒的意思是不是约束太多了的问题,但是我按实际情况必须加这么多约束,请问该怎么处理啊,MNF文件太大,传不上来,这是ANSYS命令流,直接在ANSYS中运行就能生成MNF文件,麻烦哪位高手能帮忙看下么,多谢了啊~
ERROR: At time 0.000000000E+00 the integrator is unable to proceed. Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation. The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
ERROR: Simulation failure detected.
