查看: 76|回复: 1
[ADAMS CAR, Chassis, Engine] 悬架仿真出错 求教!
发表于 2013-9-17 15:32:29 | 显示全部楼层 |阅读模式 来自 安徽合肥
Reading in property files...
Reading of property files completed.
Setting up assembly for analysis of loadcase: 'parallel_travel'...
Writing analysis information to Adams/Solver command file: '_parallel_travel'.
Simulation(s) are beginning...
   *                      MSC.Software Corporation                     *
   *                             A d a m s                             *
   *          Automatic Dynamic Analysis of Mechanical Systems         *
   *                      A d a m s / S o l v e r                      *
   *                       (Build: 2010.1.19.37)                       *
   *      2013-09-17 15:32:16              Version MD 2010             *
   *      Customer Entitlement ID:         652E109D-A4977FD5           *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=_parallel_travel
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 0.56250 seconds
   Enter ADAMS output file name or ? (default is same as input):
     Adams model file .. _parallel_travel.adm
   Default file names for output files
     Tabular output file:
     _parallel_travel.out
     Diagnostic file    :
     _parallel_travel.msg
     Message Database file    :
     _parallel_travel.mdb
     Graphics file      :
     _parallel_travel.gra
     Request file       :
     _parallel_travel.req
     Results file       :
     _parallel_travel.res
   Input Phase - Reading in Model
   Adams/Solver dataset Title:
   Adams/Car Assembly (MD Adams 2010)
ERROR:  The MARKER referenced by ID number does not exist.
ERROR:     Value               : 153
ERROR:     Argument            : J
ERROR:     Statement           : JOINT/51
ERROR:     Line number         : 3331
ERROR:     Value               : 158
ERROR:     Argument            : J
ERROR:     Statement           : JOINT/52
ERROR:     Line number         : 3337
ERROR:  Errors in the Adams dataset prevent it from being loaded into the database.
   Reading of model complete.
   Adams/Car MD Adams 2010
Processing ENVIRONMENT entries in 'C:\MSC.Software\MD_Adams\2010\acar/acar.cfg'
Processing ENVIRONMENT entries in 'C:\Documents and Settings\Administrator/.acar.cfg'
ERROR:  There is no corresponding object for this lookup index.
ERROR:     Error type:  ae_lookup_object_index
                              Adams/Tire
                         Version MD Adams 2010
   Input Phase - Populating Solver database
---- ERROR ----
   Error(s) found in input, no model available.
   Input Phase Complete.
   CPU time is 0.51562 seconds.
---- ERROR ----
   An error has been found in the model dataset supplied
   through the FILE/MODEL command.  Dataset file name is:
   Enter Command:
   preferences/solver=F77
   Enter Command:
   control/ routine=acarSDM::con950, function=user(950,29,31,1,2,18,20,1,3,2,3,28,30,2,3,28,30,1,1)
---- ERROR ----
   No model is present in memory at this instant.
   Read in an Adams/Solver data set first.
   Enter Command:
   simulate/static, end=21.000000, steps=20
---- ERROR ----
   Enter Command:
   Enter Command:
   stop
   Terminating Adams/Car usersubs...
   Adams/Solver execution terminated by subprogram A3TERM
   CPU time used = 0.51562 seconds
Simulation(s) are complete!
Loading analysis results...
ERROR: Cannot load results!  File '_parallel_travel.res' not found.
ERROR: Cannot load graphics!  File '_parallel_travel.gra' not found.
Loading results done.
本周要做汇报 十分着急 ! 求教
发表于 2013-9-25 10:13:39 | 显示全部楼层 来自 上海
检查下你的marker点
GMT+8, 2024-11-2 15:22 , Processed in 0.026644 second(s), 11 queries , Gzip On, MemCache On.
