查看: 180|回复: 2
[其他模块的使用] Adams ATV
发表于 2013-12-19 12:06:30 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
小弟最近在做一个履带车的仿真,想用Adams的专用工具箱ATV,但是目前只在网上下到了一个adams 2010的atv,按照论坛里的方法加载,但是在Message Window里出现很多error,如下:
ERROR:   ---------------------------------------------------------------------
ERROR:   Error detected on line number 13, character 52 of the macro '.ACAR.macros.mac_int_swi_aca'.
ERROR:    "acar_get_mode" is not a known constant, function or variable
ERROR:      (<<acar_get_mode>>() == "template_builder")
ERROR:   The command was not executed.
ERROR:   >> if condition=(acar_get_mode() == "template_builder")
ERROR:   Error detected on line number 18, character 44 of the macro '.ACAR.macros.mac_int_swi_aca'.
ERROR:      (<<acar_get_mode>>() != "plotting")
ERROR:   >> if condition=(acar_get_mode() != "plotting")
ERROR:   Error detected on line number 28, character 102 of the macro '.ACAR.macros.mac_int_swi_aca'.
ERROR:    "acar_set_mode" is not a known constant, function or variable
ERROR:      (<<acar_set_mode>>("acar"))
ERROR:   >> variable set variable_name=.ACAR.macros.mac_int_swi_aca.acarMode integer_value=(acar_set_mode("acar"))
ERROR:   Error detected on line number 29, character 67 of the macro '.ACAR.macros.mac_int_swi_aca'.
ERROR:   No Variable was found because 'acarMode' does not exist beneath '.ACAR.macros.mac_int_swi_aca'.
ERROR:   >> variable delete variable_name=.ACAR.macros.mac_int_swi_aca.acarMode
ERROR:   Error detected on line number 32, character 73 of the macro '.ACAR.macros.mac_int_swi_aca'.
ERROR:    "model_class_exists" is not a known constant, function or variable
ERROR:      (eval(<<model_class_exists>>("subsystem") ? "yes" : "no"))
ERROR:   &>  subsystem_exists=(eval(model_class_exists("subsystem") ? "yes" : "no")) &
ERROR:   Error detected on line number 23, character 38 of the macro '.ATV.macros.common_init'.
ERROR:    "cfg_read" is not a known constant, function or variable
ERROR:      (eval(<<cfg_read>>("atv")))
ERROR:   &>  integer_value=(eval(cfg_read("atv")))
ERROR:   Error detected on line number 18, character 94 of the macro '.ACAR.macros.mac_too_dat_upd'.
ERROR:    "cdb_get_number_of_cdbs" is not a known constant, function or variable
ERROR:      (eval(<<cdb_get_number_of_cdbs>>()))
ERROR:   >> for variable=.ACAR.macros.mac_too_dat_upd.loopcnt start=1 end=(eval(cdb_get_number_of_cdbs()))
ERROR:   Error detected on line number 67, character 50 of the macro '.ACAR.macros.mac_too_dat_upd'.
ERROR:    "cdb_get_write_default" is not a known constant, function or variable
ERROR:      (eval(<<cdb_get_write_default>>()))
ERROR:   +1&>     current_choice=(eval(cdb_get_write_default()))
ERROR:   Error detected on line number 319, character 49 of the macro '.ATV.load'.
ERROR:      (eval(<<cfg_read>>("atv_aview")))
ERROR:   +1&>     integer_value = (eval(cfg_read("atv_aview")))
ERROR:   Invalid input. Enter a number.
ERROR:   >> var set var=.ACAR.variables.vehicle_left real=
ERROR:   >> var set var=.ACAR.variables.vehicle_rear real=
ERROR:   ---------------------------------------------------------------------现在还在入门,希望做过履带车仿真的前辈们能给我指点一下:
1.网上传的ATV2010好不好使,如果好使,希望能有教程?
2.如果不通过ATV来实现,在View中实现,用什么单元来模拟履带?
发表于 2013-12-19 15:44:29 | 显示全部楼层 来自 吉林长春
我感觉履带还是用RECURDYN来分析比较方便
 楼主| 发表于 2013-12-26 09:31:00 | 显示全部楼层 来自 哈尔滨工业大学一校区
嗯,ATV走不通,只能用Recurdyn了
GMT+8, 2024-11-2 13:27 , Processed in 0.035779 second(s), 10 queries , Gzip On, MemCache On.
