查看: 71|回复: 1
[基础知识] ADAMS中两个MARKER点距离前后矛盾是怎么回事?
发表于 2014-3-5 10:52:20 | 显示全部楼层 |阅读模式 来自 湖北武汉
MARKER_82-233.3771537702, 486.5, -22.627000148),MARKER_83:(-233.3771537702, 486.5, -30.627000148),此两点明眼一看距离就为8,为何我在调用的两点距离时:-AKISPL(DM(MARKER_82,MARKER_83)-7.999,0,SPLINE_9,0)时报错:WARNING:  An Out-of-range X value has been used in the spline calculation.
Extrapolation is required for GZT_V0.SPLINE_9.
The X value (0.000671) should be between 0.001000 and 0.039000 ,按理说两都距离8减去7.999后应该是0.001啊,为什么变成了0.000671?求大神们解决,感激啊感激!
发表于 2014-3-18 15:34:54 | 显示全部楼层 来自 上海闸北区
这两个点,计算的时候有相对运动吗?
GMT+8, 2024-11-2 11:35 , Processed in 0.028297 second(s), 11 queries , Gzip On, MemCache On.
