查看: 133|回复: 3
[ADAMS CAR, Chassis, Engine] 使用ADAMS/car对电动汽车进行仿真?
发表于 2014-6-8 11:25:04 | 显示全部楼层 |阅读模式 来自 山东淄博
电动车和传统内燃机车的仿真是有区别的,在仿真工况下是否相同?如果使用仿真工况的.dcf文件进行仿真,那么.dcf文件怎么改成电动车模式的?下面为双移线仿真的.dcf文件内容:
$---------------------------------------------------------------------MDI_HEADER
[MDI_HEADER]
FILE_TYPE     = 'dcf'
FILE_VERSION  = 2.0
FILE_FORMAT   = 'ASCII'
(COMMENTS)
{comment_string}
'DCF file for Closed Loop ISO-Lane Change'
$--------------------------------------------------------------------------UNITS
[UNITS]
LENGTH  =  'meter'
FORCE   =  'newton'
ANGLE   =  'deg'
MASS    =  'kg'
TIME    =  'sec'
$---------------------------------------------------------------------EXPERIMENT
[EXPERIMENT]
EXPERIMENT_NAME = 'ISO-Lane Change'
STATIC_SETUP    = 'STRAIGHT'
INITIAL_SPEED   = 16.667
INITIAL_GEAR    = 3
(MINI_MANEUVERS)
{mini_manuever     abort_time   step_size}
'LANE_CHANGE'      12.0         0.01
$--------------------------------------------------------------------LANE_CHANGE
[LANE_CHANGE]
(STEERING)
  ACTUATOR_TYPE     =  'ROTATION'
  METHOD            =  'MACHINE'
(THROTTLE)
  METHOD            =  'MACHINE'
(BRAKING)
  METHOD            =  'MACHINE'
(GEAR)
  METHOD            =  'OPEN'
  MODE              =  'ABSOLUTE'
  CONTROL_TYPE      =  'CONSTANT'
  CONTROL_VALUE     =  3
(CLUTCH)
  METHOD            =  'OPEN'
  MODE              =  'ABSOLUTE'
  CONTROL_VALUE     =  0
(MACHINE_CONTROL)
  STEERING_CONTROL  =  'FILE'
  DCD_FILE          =  '<acar_shared>/driver_data.tbl/iso_lane_change.dcd'
  SPEED_CONTROL     =  'MAINTAIN'
  MIN_ENGINE_SPEED  =  750.0
  MAX_ENGINE_SPEED  =  6500.0
(END_CONDITIONS)
{measure       test   value   allowed_error filter_time delay_time group}
'DISTANCE'     '=='   250.00  0.5           0.0         0.0
求大师帮忙解决?改为电动车仿真模版。
发表于 2014-6-26 22:21:55 | 显示全部楼层 来自 广东深圳
应该是该发动机、变数器属性文件吧
 楼主| 发表于 2014-7-5 22:09:39 | 显示全部楼层 来自 山东淄博
xyf19870213 发表于 2014-6-26 22:21
应该是该发动机、变数器属性文件吧
关键是发动机和电机特性不一样啊
发表于 2014-7-7 22:49:41 | 显示全部楼层 来自 陕西西安
我的qq是631462810   求加为好友  一起讨论 我也在做这个东西
GMT+8, 2024-11-2 09:34 , Processed in 0.028765 second(s), 10 queries , Gzip On, MemCache On.
