进行双轮同向跳动仿真时,轮跳行程设置较小时,仿真可以完成;行程设置较大时,无法完成。
设置20mm时,仿真报错如下:
The Reconcile Acceleration-Force has detected a singular Jacobian matrix.
This problem may be caused by:
(a) A constraint equations that became almost redundant, e.g., the model
is at a singular configuration or at a bifurcation point.
(b) A massless PARTS in the model.
The Sparse Solver has detected a zero pivot for row 71 (during the symbolic pivot selection).
The corresponding equation is: Part/38 Phi Torque
A minimization algorithm will be used to find a solution on the
projected constraint manifold.
---- END: WARNING ----
Simulation Step Function Cumulative CPU
Time Size Evaluations Steps Taken time
___________ ___________ ___________ ___________ ________
1.00000E+00 0.00000E+00 0 0 1.61
5.00000E+00 1.00000E+00 59 16 1.83
9.00000E+00 1.00000E+00 79 20 2.09
1.30000E+01 1.00000E+00 99 24 2.37
1.70000E+01 1.00000E+00 119 28 2.59
2.10000E+01 1.00000E+00 139 32 2.81
2.50000E+01 1.00000E+00 159 36 3.07
2.90000E+01 1.00000E+00 179 40 3.35
3.30000E+01 1.00000E+00 199 44 3.60
3.70000E+01 1.00000E+00 219 48 3.85
Time: 3.850829315E+01.
QSTATIC: Step Size Too Small: 6.002280861E-05
End Simulation
Simulate status=-121
设置15mm时,有报错,但是仿真可以进行。
---- START: WARNING ----
1.00000E+00 0.00000E+00 0 0 1.76
5.00000E+00 1.00000E+00 59 16 2.07
9.00000E+00 1.00000E+00 79 20 2.32
1.30000E+01 1.00000E+00 99 24 2.56
1.70000E+01 1.00000E+00 119 28 2.79
2.10000E+01 1.00000E+00 139 32 3.00
2.50000E+01 1.00000E+00 159 36 3.28
2.90000E+01 1.00000E+00 179 40 3.56
3.30000E+01 1.00000E+00 199 44 3.82
3.70000E+01 1.00000E+00 219 48 4.06
4.10000E+01 1.00000E+00 239 52 4.26
End Simulation
Simulate status=0
command: !
command: stop
Termination status=0
下面是建立耦合模型的简述,求教问题出现原因?
(在2012版Car中建立的悬架模型,hypermesh12.0生成mnf文件,导入Adams,刚性外联点处建立interface part,手动将刚体的运动副、通讯器修改到柔性体上,之后删除刚体part。)
