在ADAMS中刚性体运动没问题,导入MNF文件柔性化后,出现WARNING: Model .model_1 is no longer compatible with Adams/Solver (FORTRAN). .model_1.CONTACT_1 may be causing the incompatibility because of one or more of the following: - Objects of type Contact are not compatible with Adams/Solver (FORTRAN). - The topology of the model has changed so .model_1.CONTACT_1 is no longer connected in a way that is compatible with Adams/Solver (FORTRAN).
运行出现WARNING: The number of edges does not match the number of triangles. The shell may not be water tight. If the shell is from a coarsened Flexible Body, it may experience difficulty when used in a CONTACT. ERROR: At time 0.000000000E+00 the integrator is unable to start/restart. Possible Causes: (1) The accuracy required for the numerical solution can not be attained. Relax (increase) the value of the acceptable integration ERROR. (2) Incompatible redundant constraints, a lock up, or a bifurcation situation. The latter two indicate a mechanism design problem. (3) The system includes a zero (or relatively small) mass on a part with an unconstrained translational degree of freedom. Make sure you have mass on all parts with translational degrees of freedom. (4) The system includes a zero (or relatively small) inertia on a part with an unconstrained rotational degree of freedom. Make sure you have inertias on all parts with rotational degrees of freedom. (5) An Adams element has a function expression that equals exactly itself. For example, SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4). Similarly, VARIABLE/id5, FUNC=VARVAL(id5)*TIME equals itself at 1 second. Avoid setting an Adams element equal to itself.
ERROR: Simulation failure detected. ERROR: Simulation failure detected. 有人知道怎么解决吗?
