查看: 86|回复: 0
[其他模块的使用] Vibration分析无法输出力的结果
发表于 2016-4-9 15:27:48 | 显示全部楼层 |阅读模式 来自 北京
警告信息如下:
WARNING: While processing expression "FY(43)" for MODEL_test.Output_T4.output_channel_variable
the use of an FX, FY, FZ, FM, TX, TY, TZ or TM measure
using only a single marker argument was detected.  Whereas
in the F77 Solver this measures the sum of *action-only*
forces acting at this marker, in the C++ Solver the total
sum of *all* forces acting on the marker is measured.  Please
adjust your model accordingly
但是位移和模态是有输出结果的,请大神帮忙看看到底是什么问题。
测的是一个弹簧力输出,弹簧一端与大地相连,一端与Part相连,在part上加载正弦载荷,测量弹簧与大地点相连的marker的输出力。
是否是需要增加一个弹簧的质心marker?
GMT+8, 2024-11-1 23:36 , Processed in 0.032584 second(s), 10 queries , Gzip On, MemCache On.
