- 2016-3-21
****** Performing Dynamic Simulation using Gstiff I3 Integrator ******
The system is modelled with INDEX-3 DAEs.
The integrator is GSTIFF, CORRECTOR = original
Integration error = 6.000000E-01
Drv_Vhl::ifCalcSetup
Adjusting initial value of I term of longitudinal PID
to match desired initial throttle value: 34.5633
LONGITUDINAL SETUP ITERATIONS = 2
---- START: WARNING ----
The Reconcile Acceleration-Force has detected a singular Jacobian matrix.
This problem may be caused by:
(a) A constraint equations that became almost redundant, e.g., the model
is at a singular configuration or at a bifurcation point.
(b) A massless PARTS in the model.
The Sparse Solver has detected a zero pivot for row 1096 (during the symbolic pivot selection).
The corresponding equation is: RevJnt/82 X Delta
A minimization algorithm will be used to find a solution on the
projected constraint manifold.
---- END: WARNING ----
---- START: ERROR ----
Time 8.800000E-02:
Acceleration computation failed to converge after 25 iterations.
Equation with the largest imbalance: Part/153 X Force
Imbalance = 9.280188351E-08
Variable receiving largest increment: Part/2 X Acc
Delta = 0.000000000E+00
1) Check mass and inertia properties to ensure they are valid.
2) Make sure the choice of units is appropriate for the system.
Systems that have very small inertias may benefit from "small"
force units, e.g., dynes.
3) Check that motion generators are valid and no redundant constraints exist.
4) Check if impact functions caused a strange response in the model (verify properties).
5) An IMPLICIT DIFF element which does not reference DIF1 must be satisfied by its IC.
---- END: ERROR ----
Dynamic Solution stopped.
End Simulation
Simulate status=-124
SIMULATE command failed for minimaneuver: MINI_1
Aborting Execution.
ID = 0
Adams/Solver run terminating due to STOP requested by user.
Termination status=-995
Terminating Adams/Car usersubs...
Finished -----
Elapsed time = 3.64s, CPU time = 3.85s, 105.92%
Simulation is complete.
