查看: 96|回复: 1
[其他] adams仿真出错
发表于 2017-5-5 15:09:02 | 显示全部楼层 |阅读模式 来自 江苏南京
Adams仿真是总是弹出这个错误对话框,求解?
 楼主| 发表于 2017-5-5 15:11:02 | 显示全部楼层 来自 江苏南京
生成的.dmp file 文件如下
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [E:\ADAMS working directory\r1000F1000\SCAKernel-20170505-150922-3212-6084.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 7 Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Fri May  5 15:09:22.000 2017 (GMT+8)
System Uptime: not available
Process Uptime: 0 days 0:03:18.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(c8c.17c4): Access violation - code c0000005 (first/second chance not available)
Unable to load image C:\Windows\System32\ntdll.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntdll.dll
*** ERROR: Module load completed but symbols could not be loaded for ntdll.dll
ntdll+0x4ca0a:
00000000`77a8ca0a c3
GMT+8, 2024-11-1 19:32 , Processed in 0.029203 second(s), 12 queries , Gzip On, MemCache On.
