- 2008-3-20
发表于 2017-6-2 23:23:31
来自 北京东城
请参考Primer中的Problem 19: Fluid flow and mass transfer within a pipe
先建立截面,然后都进行积分即可。
Total volume flux: To create a model point for determining the total volume flux over the
cutting plane, choose DefinitionsModel Point (Special) Mesh Integration, add point name
X_FLUX, verify that the Integration Type is Integral and click OK. Now choose List
Value ListModel Point, verify that the point name is X_FLUX, set Variable 1 to (Flux:
VOLUME_FLUX_SURFACE) and click Apply. The volume flux should be 1.09308E-4 (the
analytical solution for laminar flow is 1.18E-4). Click Close to close the dialog box. |
