查看: 105|回复: 0
[Flex及相关] 行星轮系刚柔耦合
发表于 2017-9-2 20:31:36 | 显示全部楼层 |阅读模式 来自 湖南
进行行星轮系刚柔分析时,太阳轮柔性化处理,ADAMS计算报错。求大神帮忙分析下,问题出在哪
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation.  The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
     SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
     DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
     VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
GMT+8, 2024-11-1 17:31 , Processed in 0.027291 second(s), 11 queries , Gzip On, MemCache On.
