查看: 58|回复: 0
[其他模块的使用] 振动模块中静平衡分析仿真出现错误,请教大佬
发表于 2017-11-23 18:58:17 | 显示全部楼层 |阅读模式 来自 湖南长沙
ERROR:
Static equilibrium analysis has not been successful.
  The maximum number of iterations 25, has been reached.
  For the last attempted iteration:
  The equation with the largest error was huaban_1.SPRING_22.sforce Comp = 0 Error = 20.359329
  The variable receiving the largest increment was huaban_1.lun_2 Comp = 4 Delta = 980665.000016.
ERROR:   Simulation failure detected.
GMT+8, 2024-11-1 17:36 , Processed in 0.027328 second(s), 11 queries , Gzip On, MemCache On.
