查看: 114|回复: 1
[ADAMS CAR, Chassis, Engine] 整车仿真出错
发表于 2018-2-4 10:38:47 | 显示全部楼层 |阅读模式 来自 广西柳州
---- ERROR ----
   Attempt = 1. No convergence after 25 iterations. Best iteration = 25.
   Trying next attempt with a different set of statics parameters...
   For the last attempted iteration the equation with the largest error
   was PART ww_accel.D100_body.ges_chassis  Error = 7.72019E+05
   The variable receiving the largest increment
   was PART ww_accel.powertrain.ges_powertrain  Delta = 9.810E+13
---- ERROR ----
   Static equilibrium analysis has not been successful.
   Restoring the input initial conditions...
   acar_2010.1.0/vdm::apre_fvbcsb
   **** Error:
         Sim/stat cannot be achieved.
---- ERROR ----
   Aborting Execution.
   Terminating Adams/Car usersubs...
      Adams/Solver execution terminated by subprogram ERRMES
各位大神仿真报这个错误该怎么处理呢?谢谢
发表于 2018-2-6 10:55:25 | 显示全部楼层 来自 山西运城
水平有限,简单谈下自己的感受,一般先检查子系统参数,其次是通讯器,再次就是衬套,弹簧刚度等设置对不对
GMT+8, 2024-11-1 17:32 , Processed in 0.026122 second(s), 11 queries , Gzip On, MemCache On.
