查看: 269|回复: 3
[ADAMS CAR, Chassis, Engine] 3D road仿真
发表于 2019-12-27 15:41:35 | 显示全部楼层 |阅读模式 来自 重庆沙坪坝区
3D road仿真时,使用的是自建的虚拟试验场路面模型,格式为.crg文件。但仿真时发现一个问题,车辆左侧轮胎和路面并未接触。每次仿真都会报错,静态平衡分析尚未成功,情况如下:
 楼主| 发表于 2019-12-27 15:48:37 | 显示全部楼层 来自 重庆沙坪坝区
仿真报错提醒:---- START: ERROR ----
Static equilibrium analysis has not been successful.
  The maximum number of iterations 25, has been reached.
  For the last attempted iteration:
  The equation with the largest error was model.TR_Body.ges_chassis Comp = 7 Error = 27058599.059656
  The variable receiving the largest increment was model.TR_Front_Suspension.josfix_subframe_rigid Comp = 5 Delta = 25633429.507625.
---- END: ERROR ----
  Static Solution failed to converge
  End Static Solution
  Simulate status=-124
发表于 2019-12-30 14:33:23 | 显示全部楼层 来自 山西运城
首先得保证静平衡才能进行后续仿真
发表于 2021-1-27 13:53:01 | 显示全部楼层 来自 中国
你的路面怎么建的,加QQ一起探讨,1204364027
GMT+8, 2024-11-1 11:41 , Processed in 0.034175 second(s), 12 queries , Gzip On, MemCache On.
