查看: 142|回复: 0
[ADAMS CAR, Chassis, Engine] 蛇形工况中dcf文件
发表于 2020-11-30 22:22:26 | 显示全部楼层 |阅读模式 来自 江苏
解决了一个问题,害怕自己忘记,在这里记录一下
SDF_xml_upd_controller()
Info: minPreviewDistance is negative or not set, using default 5m.
   Drv_Model::vfSetMaxLenItx
Info: MaxLenItx is negative or not set, using default (100m).
---- START: ERROR ----
invalid string position
---- END: ERROR ----
command: control/ routine=abgVDM::EventRunAll, function=user(0)
vdm::EventRunAll
   WARNING: No event exists.  You must first initialize and event before
            event by issuing the command:
            CONTROL/ FUNC=USER(0), ROUTINE=abgVDM::EventInit
command: !
command: stop
  Termination status=0
Terminating Adams/Car usersubs...
Finished -----
Elapsed time = 1.89s,  CPU time = 1.84s,  97.14%
Simulation is complete.
是由于引用文件正确是dcd_file自己多加了一个name
GMT+8, 2024-11-1 11:36 , Processed in 0.030693 second(s), 11 queries , Gzip On, MemCache On.
