查看: 555|回复: 6
【求助】johnson_liao 请来看看(acf for engine)
发表于 2002-12-15 10:45:24 | 显示全部楼层 |阅读模式 来自 武汉大学
我在ADAMS/ENGINE里面,作一个传动系统的模型,现在做到变速箱部分,需要在仿真过程中换档,就是能够实现动态换档的仿真,想通过改变约束(fix joint)来实现,可是Engine里不能通过Scipt control,改怎样实现呢?
谢谢!
发表于 2002-12-30 23:57:25 | 显示全部楼层 来自 泰国
回复: 【求助】johnson_liao 请来看看
You can run *.adm with ACF file.
Please try it !!!
Johnson
 楼主| 发表于 2003-1-2 10:02:51 | 显示全部楼层 来自 武汉大学
thank you, johnson, I have done as you told if I understand right: I choose the simulate options as "files_only" in adams/engine and I got the *.adm and *.acf file, then I import the *.adm into adams/view and simulate with the modified *.acf file, but I get the following error, the message show it need a userdefined GFOSUB, but wrote no subroutine:
 楼主| 发表于 2003-1-2 10:05:45 | 显示全部楼层 来自 武汉大学
and I tried another one, even I did not use the *.acf file, just the interactive simulate, the error will appear. How to deal with this?
thank you1
发表于 2003-1-2 20:46:14 | 显示全部楼层 来自 Invalid
this is a ACF file  for a/Engine.
file/model=mm_generic
output/noreqsave, noseparator
control/function=user(801,4,5)
equil/sta=1,tlim=1,alim=0.5,maxit=200,err=100,imb=100
simulate/statics
equil/sta=0.1,tlim=0.5,alim=5d,maxit=30,err=10,imb=10
simulate/statics
equil/sta=0.001000,tlim=1.000000,alim=10.000000,maxit=25,err=0.000100,imb=0.010000
simulate/statics
output/reqsave
simulate/dynamics, end=10.0, steps=100
stop
you can  use ACTIVATE/DEACTIVATE to control them.
ADAMSR12 ae ru-solv xx.acf
Johnson
 楼主| 发表于 2003-1-3 10:10:06 | 显示全部楼层 来自 广东深圳
thank you johnson, if this work, how to get the simulate results
发表于 2003-1-3 15:21:29 | 显示全部楼层 来自 台湾
You can import *.res, *.gra and *.req
Johnson
GMT+8, 2024-11-2 11:38 , Processed in 0.036539 second(s), 10 queries , Gzip On, MemCache On.
