- 2006-3-18
发表于 2006-6-20 21:45:05
来自 北京
各位高手,我最近也在学习整车模型方面的知识。模型是我在PROE里面建立的,然后导入ADAMS里面去,模型本身在验证的时候没有问题,可是当我加入轮胎模型和路面谱的时候却出现了如下的警告信息:
WARNING: Model .MPRO_model is no longer compatible with the ADAMS/Solver (C++).
.MPRO_model.TIRE_1 is causing the incompatibility because:
1) Objects of type Tire are not compatible with the
ADAMS/Solver (C++).
2) The topology of the model has changed so .MPRO_model.TIRE_1
is no longer connected in a way that is compatible with the
ADAMS/Solver (C++).
3) An attribute of .MPRO_model.TIRE_1 is no longer compatible with
If you intend to use the ADAMS/Solver (C++), then be sure that you
set your preferences so ADAMS/Solver (C++) is the default as follows:
- From the Settings menu, point to Solver and select either
Solver Executable or Preferences, depending on the product
you are using.
- To learn more, press F1 in the dialog box.
If you do not want to use the ADAMS/Solver (C++), you must change
your model to eliminate the incompatibility. For more information,
see the online help for the object listed.
比较急,希望哪位高手可以指点一二,多谢! |
