- 2004-5-10
发表于 2004-9-9 13:38:25
来自 江西南昌
回复: 【讨论】李军整车模型修改大全! 欢迎补充
wangzx你好,首先谢谢你的答复,但是我这个提示出现后仿真就失败了,并不是象MSC专家所说的那样,具体提示如下,还望帮着解决万分感谢!
WARNING: For TIRE jeep.TIRE_1 the absolute value of the longitudinal slip ratio
has gone beyond its maximum allowable limit of 1.0.
Longitudinal slip ratio = 1.0247.
If the longitudinal slip ratio is positive, it will be set
to 1.0 (braking). If the longitudinal slip ratio is
negative, it will be set to -1.0 (traction).
WARNING: For TIRE jeep.TIRE_3 the absolute value of the longitudinal slip ratio
Longitudinal slip ratio = 1.0038.
WARNING: For TIRE jeep.TIRE_3 the lateral slip ratio has gone beyond its
Lateral slip angle (alpha) = -1.1956.
Lateral slip ratio (S_alpha) is being set to 1.0.
WARNING: For TIRE jeep.TIRE_3 the lateral slip value due to combined slip
and camber has gone beyond its maximum allowable limit of 1.0.
Camber angle (gamma) = 2.32903E-02.
Combined lateral slip ratio due to slip angle and Camber angle
(S_alpha_gamma) is being set to 1.0.
WARNING: For TIRE jeep.TIRE_3 the comprehensive slip value due to longitudinal
slip, lateral slip and camber has gone beyond its maximum allowable
limit of 1.0.
Longitudinal slip (s) = 0.30616.
Comprehensive slip (S_slip_alpha_gamma) = 1.0458.
It is being set to 1.0.
WARNING: For TIRE jeep.TIRE_4 the lateral slip ratio has gone beyond its
Lateral slip angle (alpha) = -1.2949.
WARNING: For TIRE jeep.TIRE_4 the lateral slip value due to combined slip
Camber angle (gamma) = -1.59308E-02.
WARNING: For TIRE jeep.TIRE_4 the comprehensive slip value due to longitudinal
limit of 1.0.
Longitudinal slip (s) = 6.16217E-02.
Comprehensive slip (S_slip_alpha_gamma) = 1.0019.
WARNING: For TIRE jeep.TIRE_4 the absolute value of the longitudinal slip ratio
Longitudinal slip ratio = 1.1533.
Lateral slip angle (alpha) = -1.0931.
Camber angle (gamma) = -1.59243E-02.
limit of 1.0.
Longitudinal slip (s) = 0.44976.
Comprehensive slip (S_slip_alpha_gamma) = 1.0965.
Longitudinal slip ratio = 1.0866.
Longitudinal slip ratio = 1.2997.
Lateral slip angle (alpha) = -1.1171.
Camber angle (gamma) = 1.59320E-02.
limit of 1.0.
Longitudinal slip (s) = 0.71257.
Comprehensive slip (S_slip_alpha_gamma) = 1.2279.
Longitudinal slip ratio = 1.0231.
WARNING: For TIRE jeep.TIRE_1 the lateral slip ratio has gone beyond its
Lateral slip angle (alpha) = -0.81662.
WARNING: For TIRE jeep.TIRE_1 the lateral slip value due to combined slip
Camber angle (gamma) = 2.70006E-02.
WARNING: A total of 20 warnings have been issued for trimming of slip
values that have exceeded their limits. ADAMS will no longer
issue warnings when it trims longitudinal slip ratios,
lateral slip ratios due to slip angle, lateral slip ratios
due to combined slip and camber angles, and comprehensive
slip values.
WARNING: The symbolic refactorization failed. The matrix is structurally singular
at time = 1.48612E-03.
WARNING: The corrector has not converged after 6 attempts. No. of iterations = 10.
WARNING: The corrector has not converged after 2 attempts. No. of iterations = 10.
WARNING: The corrector has not converged after 2 attempts. No. of iterations = 20.
ERROR: The simulation stopped at time = 3.83226E-03 . ADAMS cannot solve
the equations of motion.
The greatest error in an equation is 99016. in the
equation for GFORCE jeep.TIRE_1.GFORCE_16912385 .
The greatest change in a variable is 2.56407E-13 in the
variable for PART jeep.centerlink .
Try the following in this order:
1. Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
or INTEGRATOR command to increase the maximum number of
iterations.
2. Temporarily change the value of the PATTERN argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
 ATTERN = T.
3. Temporarily increase the value of the ERROR argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
4. If one or more forces change rapidly or sharply near
time = 3.83226E-03, modify the force or forces.
ERROR: Simulation failure detected |
