楼主: cyj198148
大家一起学ADINA,贡献流固耦合的例子
发表于 2007-9-10 10:21:34 | 显示全部楼层 来自 黑龙江哈尔滨
楼主太大公无私了,学习
发表于 2007-9-12 22:52:45 | 显示全部楼层 来自 湖北武汉
step by step! thanks.
发表于 2007-9-17 16:43:36 | 显示全部楼层 来自 北京交通大学
呵呵,好好学习!
谢谢!
顺便问一下,有人做过风压方面的例子吗?邮箱pflily@126.com,谢谢大家。
发表于 2007-10-9 22:33:08 | 显示全部楼层 来自 江苏南通
多谢,正在研究
发表于 2007-12-1 11:28:20 | 显示全部楼层 来自 陕西西安
学习中
谢谢楼主
发表于 2007-12-1 15:36:59 | 显示全部楼层 来自 上海
很好,谢谢分享
发表于 2007-12-4 13:33:09 | 显示全部楼层 来自 上海
暂时还不需要研究流体
发表于 2008-1-8 14:22:36 | 显示全部楼层 来自 湖北宜昌
感激一哈子~!!
发表于 2008-1-8 15:14:28 | 显示全部楼层 来自 浙江杭州
请教楼主,为何我照着你的说明做了一下,运行到20步左右的时候出现如下的错误呢?
*** WARNING *** CODE ADF2704:
    Fluid node (label) 561 is not attached to boundary geometry 1.
    The relative distance to boundary cell 1 is 5.01E-01.
    The fluid nodal coordinates are (0.00E+00, 1.17E-04, 6.01E-01)
    The points and their coordinates of the boundary cell are:
        point       1 = ( 0.000E+00, 0.000E+00, 0.000E+00)
        point       2 = ( 0.000E+00, -1.20E+00, 0.000E+00)
    It is normal to have a small distance between fluid nodes and boundary
    geometry. The relative distance here is defined as the ratio of the
    distance between the fluid node and the closest boundary cell to the
    length of the cell.
    Note: The boundary geometry is internally generated by the program.
     ITE=     1   0.253323E-01  0.105311E-01            1  0.249503E-02           85  0.119064E+06            0.00          0.00
    The relative distance to boundary cell 1 is 5.10E-01.
    The fluid nodal coordinates are (0.00E+00, 1.21E-04, 6.12E-01)
     ITE=     2   0.263413E-02  0.102830E-02            1  0.250204E-02           85  0.119020E+06            0.00          0.00
     RESTART DATA SAVED AT TIME   0.420000E+01
     INITIAL TIME..................................... =  0.42000000E+01
     TIME STEP LENGTH................................. =  0.20000000E+00
     TIME STEP........................................ =           22
     EQUILIBRIUM   RELATIVE RESIDUALS OF          MAXIMUM DISPLACEMENT          MAXIMUM STRESS            SOLUTION TIME TIMES
     ITERATION     DISPLACEMENT    STRESS       SOLID NODE     MAGNITUDE   SOLID NODE     MAGNITUDE      SOLID MODEL   FLUID MODEL
    The relative distance to boundary cell 1 is 5.90E-01.
    The fluid nodal coordinates are (0.00E+00, 1.40E-04, 7.08E-01)
    length of the cell.
     ITE=     1   0.266672E-01  0.111843E-01            1  0.257446E-02           85  0.118963E+06            0.00          0.00
    The relative distance to boundary cell 1 is 5.99E-01.
    The fluid nodal coordinates are (0.00E+00, 1.44E-04, 7.18E-01)
     ITE=     2   0.231977E-02  0.920841E-03            1  0.258082E-02           85  0.118914E+06            0.00          0.00
     RESTART DATA SAVED AT TIME   0.440000E+01
     INITIAL TIME..................................... =  0.44000000E+01
     TIME STEP........................................ =           23
    The relative distance to boundary cell 1 is 6.86E-01.
    The fluid nodal coordinates are (0.00E+00, 1.66E-04, 8.23E-01)
    length of the cell.
     ITE=     1   0.273807E-01  0.115610E-01            1  0.265753E-02           85  0.118780E+06            0.00          0.00
    The relative distance to boundary cell 1 is 6.94E-01.
    The fluid nodal coordinates are (0.00E+00, 1.70E-04, 8.33E-01)
     ITE=     2   0.183859E-02  0.743956E-03            1  0.266274E-02           85  0.118725E+06            0.00          0.00
     RESTART DATA SAVED AT TIME   0.460000E+01
     INITIAL TIME..................................... =  0.46000000E+01
     TIME STEP........................................ =           24
    The relative distance to boundary cell 1 is 7.88E-01.
    The fluid nodal coordinates are (0.00E+00, 1.93E-04, 9.45E-01)
    length of the cell.
     ITE=     1   0.275779E-01  0.117817E-01            1  0.274241E-02           85  0.118514E+06            0.00          0.00
    The relative distance to boundary cell 1 is 7.94E-01.
    The fluid nodal coordinates are (0.00E+00, 1.97E-04, 9.53E-01)
     ITE=     2   0.127288E-02  0.540870E-03            1  0.274614E-02           85  0.118458E+06            0.00          0.00
     RESTART DATA SAVED AT TIME   0.480000E+01
     INITIAL TIME..................................... =  0.48000000E+01
     TIME STEP........................................ =           25
    The relative distance to boundary cell 1 is 8.93E-01.
    The fluid nodal coordinates are (0.00E+00, 2.22E-04, 1.07E+00)
    length of the cell.
     ITE=     1   0.271382E-01  0.117250E-01            1  0.282690E-02           85  0.118160E+06            0.00          0.00
    The relative distance to boundary cell 1 is 8.98E-01.
    The fluid nodal coordinates are (0.00E+00, 2.26E-04, 1.07E+00)
     ITE=     2   0.660572E-03  0.329948E-03            1  0.282891E-02           85  0.118111E+06            0.00          0.00
     RESTART DATA SAVED AT TIME   0.500000E+01
     INITIAL TIME..................................... =  0.50000000E+01
     TIME STEP........................................ =           26
*** ERROR *** CODE ADF2704:
    The relative distance to boundary cell 1 is 1.00E+00.
    The fluid nodal coordinates are (0.00E+00, 2.52E-04, 1.20E+00)
    length of the cell.
     ADFSI VERSION 8.4.2   (BUILT ON 03-23-2007)
     FOR PROBLEM: FSI problem
     LICENSED FROM   A D I N A  R & D  INC.
     *                                    S O L U T I O N   T I M E   L O G (IN SECONDS)                                     *
              CPU IN PROGRAM CONTROL..........................................................        0.24
              CPU IN SOLID MODEL..............................................................        0.76
              CPU IN FLUID MODEL..............................................................       19.83
                 CPU IN INPUT PHASE...........................................................        0.50
                 CPU IN ASSEMBLY..............................................................       12.99
                 CPU IN SOLVER................................................................        4.02
                    IN SYMBOLIC FACTORIZATION.................................................        0.00
                    IN NUMERIC FACTORIZATION..................................................        3.70
                    IN GENERATION OF IRA......................................................        0.01
                    IN OTHER COMPUTATION IN SOLVER............................................        0.31
                 CPU IN MOVING-MESH COMPUTATION...............................................        0.40
                    IN BOUNDARY ALE...........................................................        0.00
                    IN DOMAIN ALE.............................................................        0.40
                 CPU IN OUTPUT................................................................        1.92
              T O T A L  S O L U T I O N  T I M E.............................................       20.83
好象是说节点561已经脱离约束了,然后我想直接把这个点赋予0速度值,然后错误就更多了,所以请问如何解决的
发表于 2008-1-9 09:41:38 | 显示全部楼层 来自 天津
不错不错,学习呀·············
发表于 2008-5-23 12:55:36 | 显示全部楼层 来自 湖南长沙
学习一下,,,
发表于 2008-5-23 21:08:14 | 显示全部楼层 来自 山东济南
回复 1# 的帖子
感谢楼主,好人啊
GMT+8, 2024-11-2 17:28 , Processed in 0.050584 second(s), 8 queries , Gzip On, MemCache On.
