查看: 395|回复: 14
[ADAMS CAR, Chassis, Engine] Fila轮胎模型的侧偏刚度怎样修改?
发表于 2005-11-3 23:55:28 | 显示全部楼层 |阅读模式 来自 同济大学
$--------------------------------------------------------------------------UNITS
[UNITS]
LENGTH              = 'mm'
FORCE               = 'newton'
ANGLE               = 'radians'
MASS                = 'kg'
TIME                = 'sec'
$--------------------------------------------------------------------------MODEL
[MODEL]
!   use mode   1  2  3  4
!   smoothing      X  X
!       combined    X    X
PROPERTY_FILE_FORMAT    = 'PAC89'
FUNCTION_NAME           = 'TYR900'
USE_MODE                = 4.0
$----------------------------------------------------------------------DIMENSION
[DIMENSION]
UNLOADED_RADIUS         = 326.0
WIDTH                   = 245.0
ASPECT_RATIO            = 0.35
$----------------------------------------------------------------------PARAMETER
[PARAMETER]
VERTICAL_STIFFNESS      = 310.0
VERTICAL_DAMPING        = 3.1
LATERAL_STIFFNESS       = 190.0
ROLLING_RESISTANCE   = 0.0
$--------------------------------------------------------------------------shape
[SHAPE]
{radial width}
1.0    0.0
1.0    0.2
1.0    0.4
1.0    0.5
1.0    0.6
1.0    0.7
1.0    0.8
1.0    0.85
1.0    0.9
0.9    1.0
$-----------------------------------------------------------LATERAL_COEFFICIENTS
[LATERAL_COEFFICIENTS]
a0  =  1.65000
a1  = -34.0
a2  =  1250.00
a3  =  3036.00
a4  =  12.80
a5  =  0.00501
a6  = -0.02103
a7  =  0.77394
a8  =  0.0022890
a9  =  0.013442
a10 =  0.003709
a11 =  19.1656
a12 =  1.21356
a13 =  6.26206
$-------------------------------------------------------------------longitudinal
[LONGITUDINAL_COEFFICIENTS]
b0  =  2.37272
b1  = -9.46000
b2  =  1490.00
b3  =  130.000
b4  =  276.000
b5  =  0.08860
b6  =  0.00402
b7  = -0.06150
b8  =  1.20000
b9  =  0.02990
b10 = -0.17600
$----------------------------------------------------------------------aligning
[ALIGNING_COEFFICIENTS]
c0  =  2.34000
c1  =  1.4950
c2  =  6.416654
c3  = -3.57403
c4  = -0.087737
c5  =  0.098410
c6  =  0.0027699
c7  = -0.0001151
c8  =  0.1000
c9  = -1.33329
c10 =  0.025501
c11 = -0.02357
c12 =  0.03027
c13 = -0.0647
c14 =  0.0211329
c15 =  0.89469
c16 = -0.099443
c17 = -3.336941
 楼主| 发表于 2005-11-3 23:57:09 | 显示全部楼层 来自 同济大学
Re:Fila轮胎模型的侧偏刚度怎样修改?
修改哪些参数可以把该轮胎的侧偏刚度增大/减小25%呢?
发表于 2005-11-4 08:38:16 | 显示全部楼层 来自 安徽芜湖
可以看一下魔术公式,那里有影响侧偏刚度的因子
 楼主| 发表于 2005-11-7 19:35:28 | 显示全部楼层 来自 同济大学
哦,谢谢!
发表于 2005-11-7 23:50:35 | 显示全部楼层 来自 上海虹口区
这不是fila 模型,如果用fila 模型这些刚度定义就比较明显了。
发表于 2005-11-7 23:51:39 | 显示全部楼层 来自 上海虹口区
魔术公式比较复杂,如果要求的精度不太高的话,没必要用魔术公式。
 楼主| 发表于 2005-11-9 20:52:41 | 显示全部楼层 来自 同济大学
我做操稳,所以选用Fila模型就够满足精度了。
上面确实是Fila模型,后面的那些系数好象是在拟合侧向力、纵向力和回正力矩吧,不太拿得准!也不知道是用什么样的式子拟合的,所以迷惑。
前面给出的那些参数倒是看得懂!
 楼主| 发表于 2005-11-9 20:54:21 | 显示全部楼层 来自 同济大学
谢谢指教!
发表于 2008-3-31 17:25:24 | 显示全部楼层 来自 江苏镇江
同问,help
发表于 2008-4-1 13:02:34 | 显示全部楼层 来自 吉林长春
回复 1# 的帖子
将a3乘以或者除以25%就是对应的侧偏刚度提高减小25%,别的不用动,你可以试试,多看看pac89的拟合公式和含义,B=BCD/CD  B是刚度,在CD不变的情况下,提高BCD就可以了。不明白的话再留言吧
发表于 2010-3-22 10:53:23 | 显示全部楼层 来自 北京海淀
学习中!!
发表于 2010-3-23 21:35:37 | 显示全部楼层 来自 广东深圳
大哥,这个不是魔术公式轮胎pacejka轮胎吗,不叫fila
发表于 2010-3-23 21:45:58 | 显示全部楼层 来自 广东深圳
发表于 2010-3-26 14:42:17 | 显示全部楼层 来自 重庆沙坪坝区
这个就是魔术论坛公式,bcd等于斜率,b为刚度因子。
发表于 2013-5-21 16:01:09 | 显示全部楼层 来自 湖北武汉
请教大侠:BCD公式中的Fz和r怎么计算啊?
GMT+8, 2024-11-2 19:35 , Processed in 0.063328 second(s), 10 queries , Gzip On, MemCache On.
