查看: 307|回复: 3
急求教adina网格问题!
发表于 2006-3-24 20:19:36 | 显示全部楼层 |阅读模式 来自 湖北武汉
我费了很大的劲划分了网格,结果告诉我下列警告:
***WARNING: No element connection for node 1 directions 1, 4, 5, 6
             No element connection for node 3 directions 1, 4, 5, 6
             No element connection for node 5 directions 1, 4, 5, 6
             No element connection for node 7 directions 1, 4, 5, 6
             No element connection for node 8 directions 1, 4, 5, 6
             No element connection for node 9 directions 1, 4, 5, 6
             No element connection for node 10 directions 1, 4, 5, 6
             No element connection for node 11 directions 1, 4, 5, 6
             No element connection for node 13 directions 1, 4, 5, 6
             No element connection for node 14 directions 1, 4, 5, 6
             No element connection for node 15 directions 1, 4, 5, 6
             No element connection for node 17 directions 1, 4, 5, 6
             No element connection for node 18 directions 1, 4, 5, 6
             No element connection for node 19 directions 1, 4, 5, 6
             No element connection for node 21 directions 1, 4, 5, 6
             No element connection for node 22 directions 1, 4, 5, 6
             No element connection for node 23 directions 1, 4, 5, 6
             No element connection for node 26 directions 1, 4, 5, 6
             No element connection for node 28 directions 1, 4, 5, 6
             No element connection for node 29 directions 1, 4, 5, 6
             No element connection for node 30 directions 1, 4, 5, 6
             No element connection for node 31 directions 1, 4, 5, 6
             No element connection for node 32 directions 1, 4, 5, 6
             No element connection for node 33 directions 1, 4, 5, 6
             No element connection for node 34 directions 1, 4, 5, 6
             No element connection for node 35 directions 1, 4, 5, 6
             No element connection for node 36 directions 1, 4, 5, 6
             No element connection for node 37 directions 1, 4, 5, 6
             No element connection for node 38 directions 1, 4, 5, 6
             No element connection for node 39 directions 1, 4, 5, 6
             No element connection for node 40 directions 1, 4, 5, 6
             No element connection for node 41 directions 1, 4, 5, 6
             No element connection for node 42 directions 1, 4, 5, 6
             No element connection for node 43 directions 1, 4, 5, 6
             No element connection for node 44 directions 1, 4, 5, 6
             No element connection for node 45 directions 1, 4, 5, 6
             No element connection for node 46 directions 1, 4, 5, 6
             No element connection for node 47 directions 1, 4, 5, 6
             No element connection for node 48 directions 1, 4, 5, 6
             No element connection for node 49 directions 1, 4, 5, 6
             No element connection for node 50 directions 1, 4, 5, 6
             No element connection for node 51 directions 1, 4, 5, 6
             No element connection for node 52 directions 1, 4, 5, 6
             No element connection for node 53 directions 1, 4, 5, 6
             No element connection for node 54 directions 1, 4, 5, 6
             No element connection for node 55 directions 1, 4, 5, 6
             No element connection for node 56 directions 1, 4, 5, 6
             No element connection for node 57 directions 1, 4, 5, 6
             No element connection for node 58 directions 1, 4, 5, 6
             No element connection for node 59 directions 1, 4, 5, 6
             Message limit reached - above message has been suppressed 176 times.
             Nodal degrees of freedom without element
             connection have been fixed for ADINA input data.
             There may still be degrees of freedom without
             stiffness - see documentation.
还有个错误!
***INPUT ERROR: Material 1 for element group 1
                 requires temperature data, either input or from file.
因为毕业,adina又刚学,急请高手指点!!!
发表于 2006-3-27 09:52:36 | 显示全部楼层 来自 湖南长沙
Re:急求教adina网格问题!
应该是平面模型,约束这几个自由度就可以了。 下面一个错误则是要一个温度荷载,你可能用的是邓肯张吧。
发表于 2010-11-27 20:07:05 | 显示全部楼层 来自 天津
我也有同样的问题,哪个会的给个解决方法啊,尤其是怎么解决温度的问题~万分感谢哈!!
发表于 2010-11-29 13:26:38 | 显示全部楼层 来自 浙江杭州
平面问题,没关系,可以得到结果
GMT+8, 2024-11-2 03:40 , Processed in 0.068517 second(s), 13 queries , Gzip On, MemCache On.
