- 2006-11-11
发表于 2007-4-28 10:07:15
来自 北京
给你一个我建的模型命令流!
COORDINATES POINT SYSTEM=0
@CLEAR
1 0.00000000000000 0.00000000000000 0.962100000000000 0
2 0.00000000000000 3.96550000000000 -0.481300000000000 0
3 0.00000000000000 -1.71330000000000 -2.32530000000000 0
4 0.00000000000000 0.00000000000000 1.26870000000000 0
5 0.00000000000000 1.71330000000000 -2.32530000000000 0
6 0.00000000000000 -3.96550000000000 -0.481300000000000 0
7 0.00000000000000 0.00000000000000 -2.00000000000000 0
8 0.00000000000000 0.00000000000000 5.81210000000000 0
9 0.00000000000000 -4.55750000000000 2.62090000000000 0
10 0.00000000000000 -4.66110000000000 -3.28250000000000 0
11 0.00000000000000 -3.04420000000000 -5.12430000000000 0
12 0.00000000000000 3.04420000000000 -5.12430000000000 0
13 0.00000000000000 4.66110000000000 -3.28250000000000 0
14 0.00000000000000 4.55750000000000 2.62090000000000 0
15 0.00000000000000 0.00000000000000 10.3121000000000 0
16 0.00000000000000 -8.78610000000000 4.16000000000000 0
17 0.00000000000000 -8.94110000000000 -4.67240000000000 0
18 0.00000000000000 -4.97650000000000 -9.18830000000000 0
19 0.00000000000000 4.97650000000000 -9.18830000000000 0
20 0.00000000000000 8.94110000000000 -4.67240000000000 0
21 0.00000000000000 8.78610000000000 4.16000000000000 0
22 0.00000000000000 0.00000000000000 40.0000000000000 0
23 0.00000000000000 -40.0000000000000 40.0000000000000 0
24 0.00000000000000 -40.0000000000000 -40.0000000000000 0
25 0.00000000000000 -15.0000000000000 -40.0000000000000 0
26 0.00000000000000 15.0000000000000 -40.0000000000000 0
27 0.00000000000000 40.0000000000000 -40.0000000000000 0
28 0.00000000000000 40.0000000000000 40.0000000000000 0
LINE ARC NAME=1 MODE=1 P1=8 P2=9 CENTER=1 PCOINCID=YES,
PTOLERAN=1.00000000000000E-05
LINE ARC NAME=2 MODE=1 P1=9 P2=10 CENTER=2 PCOINCID=YES,
LINE ARC NAME=3 MODE=1 P1=10 P2=11 CENTER=3 PCOINCID=YES,
LINE ARC NAME=4 MODE=1 P1=11 P2=12 CENTER=4 PCOINCID=YES,
LINE ARC NAME=5 MODE=1 P1=12 P2=13 CENTER=5 PCOINCID=YES,
LINE ARC NAME=6 MODE=1 P1=13 P2=14 CENTER=6 PCOINCID=YES,
LINE ARC NAME=7 MODE=1 P1=14 P2=8 CENTER=1 PCOINCID=YES,
LINE ARC NAME=8 MODE=1 P1=15 P2=16 CENTER=1 PCOINCID=YES,
LINE ARC NAME=9 MODE=1 P1=16 P2=17 CENTER=2 PCOINCID=YES,
LINE ARC NAME=10 MODE=1 P1=17 P2=18 CENTER=3 PCOINCID=YES,
LINE ARC NAME=11 MODE=1 P1=18 P2=19 CENTER=4 PCOINCID=YES,
LINE ARC NAME=12 MODE=1 P1=19 P2=20 CENTER=5 PCOINCID=YES,
LINE ARC NAME=13 MODE=1 P1=20 P2=21 CENTER=6 PCOINCID=YES,
LINE ARC NAME=14 MODE=1 P1=21 P2=15 CENTER=1 PCOINCID=YES,
SURFACE VERTEX NAME=1 P1=4 P2=8 P3=9 P4=4
SURFACE VERTEX NAME=2 P1=4 P2=9 P3=10 P4=7
SURFACE VERTEX NAME=3 P1=7 P2=10 P3=11 P4=7
SURFACE VERTEX NAME=4 P1=7 P2=11 P3=12 P4=7
SURFACE VERTEX NAME=5 P1=7 P2=12 P3=13 P4=7
SURFACE VERTEX NAME=6 P1=7 P2=13 P3=14 P4=4
SURFACE VERTEX NAME=7 P1=4 P2=14 P3=8 P4=4
SURFACE VERTEX NAME=8 P1=8 P2=15 P3=16 P4=9
SURFACE VERTEX NAME=9 P1=9 P2=16 P3=17 P4=10
SURFACE VERTEX NAME=10 P1=10 P2=17 P3=18 P4=11
SURFACE VERTEX NAME=11 P1=11 P2=18 P3=19 P4=12
SURFACE VERTEX NAME=12 P1=12 P2=19 P3=20 P4=13
SURFACE VERTEX NAME=13 P1=13 P2=20 P3=21 P4=14
SURFACE VERTEX NAME=14 P1=14 P2=21 P3=15 P4=8
SURFACE VERTEX NAME=15 P1=15 P2=22 P3=23 P4=16
SURFACE VERTEX NAME=16 P1=23 P2=16 P3=17 P4=24
SURFACE VERTEX NAME=17 P1=17 P2=24 P3=25 P4=18
SURFACE VERTEX NAME=18 P1=18 P2=25 P3=26 P4=19
SURFACE VERTEX NAME=19 P1=19 P2=26 P3=27 P4=20
SURFACE VERTEX NAME=20 P1=20 P2=27 P3=28 P4=21
SURFACE VERTEX NAME=21 P1=21 P2=28 P3=22 P4=15
SURFACE EXTRUDED NAME=22 LINE=1 DX=9.0000000000000,
DY=0.00000000000000 DZ=0.00000000000000 SYSTEM=0 PCOINCID=YES,
PTOLERAN=1.00000000000000E-05 NDIV=3 OPTION=VECTOR
@CLEAR
2
3
4
5
6
7
VOLUME EXTRUDED NAME=1 SURFACE=1 DX=9.0000000000000,
@CLEAR
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
SURFACE EXTRUDED NAME=86 LINE=46 DX=9.0000000000000,
@CLEAR
46
48
50
52
54
56
57
VOLUME EXTRUDED NAME=22 SURFACE=31 DX=9.0000000000000,
@CLEAR
31
34
36
38
40
42
43
47
50
53
56
59
62
64
68
71
74
77
80
83
85
FIXITY NAME=XF
@CLEAR
'X-TRANSLATION'
'OVALIZATION'
FIXITY NAME=YF
@CLEAR
'Y-TRANSLATION'
'OVALIZATION'
FIXITY NAME=ZF
@CLEAR
'Z-TRANSLATION'
'OVALIZATION'
FIXBOUNDARY SURFACES FIXITY=ALL
@CLEAR
1 'XF'
2 'XF'
3 'XF'
4 'XF'
5 'XF'
6 'XF'
7 'XF'
8 'XF'
9 'XF'
10 'XF'
11 'XF'
12 'XF'
13 'XF'
14 'XF'
15 'XF'
16 'XF'
17 'XF'
18 'XF'
19 'XF'
20 'XF'
21 'XF'
95 'XF'
98 'XF'
100 'XF'
104 'XF'
102 'XF'
106 'XF'
107 'XF'
111 'XF'
114 'XF'
117 'XF'
120 'XF'
123 'XF'
126 'XF'
128 'XF'
132 'XF'
135 'XF'
138 'XF'
141 'XF'
144 'XF'
147 'XF'
149 'XF'
81 'YF'
145 'YF'
70 'YF'
134 'YF'
72 'ZF'
75 'ZF'
78 'ZF'
136 'ZF'
139 'ZF'
142 'ZF'
LOAD MASS-PROPORTIONAL NAME=1 MAGNITUD=9.80000000000000,
AX=0.00000000000000 AY=0.00000000000000 AZ=-1.00000000000000,
INTERPRE=BODY-FORCE
APPLY-LOAD BODY=0
@CLEAR
1 'MASS-PROPORTIONAL' 1 'MODEL' 0 0 1 0.00000000000000 0 -1 0 0 0 ,
'NO' 0.00000000000000 0.00000000000000 1 0
MATERIAL MOHR-COULOMB NAME=1 E=1.00000000000000E+09,
NU=0.350000000000000 PHI=27.0000000000000 PSI=0.00000000000000,
COH=200000.000000000 TCUT=1.00000000000000E+10,
DENSITY=2000.00000000000 DILATION=NO MDESCRIP='NONE'
MATERIAL MOHR-COULOMB NAME=2 E=1.20000000000000E+09,
NU=0.350000000000000 PHI=40.0000000000000 PSI=0.00000000000000,
COH=300000.000000000 TCUT=1.00000000000000E+10,
STRAIN-FIELD NAME=1 A=-800000.000000000 B=20000.0000000000,
C=0.350000000000000 D=0.00000000000000 E=0.00000000000000,
F=0.00000000000000
AXES CONSTANT NAME=1 AX=1.00000000000000 AY=0.00000000000000,
AZ=0.00000000000000 BX=0.00000000000000 BY=1.00000000000000,
BZ=0.00000000000000
SFTHICKNESS
@CLEAR
22 0.300000000000000 0.00000000000000 0.00000000000000,
23 0.300000000000000 0.00000000000000 0.00000000000000,
24 0.300000000000000 0.00000000000000 0.00000000000000,
25 0.300000000000000 0.00000000000000 0.00000000000000,
26 0.300000000000000 0.00000000000000 0.00000000000000,
27 0.300000000000000 0.00000000000000 0.00000000000000,
28 0.300000000000000 0.00000000000000 0.00000000000000,
86 0.300000000000000 0.00000000000000 0.00000000000000,
87 0.300000000000000 0.00000000000000 0.00000000000000,
88 0.300000000000000 0.00000000000000 0.00000000000000,
89 0.300000000000000 0.00000000000000 0.00000000000000,
90 0.300000000000000 0.00000000000000 0.00000000000000,
91 0.300000000000000 0.00000000000000 0.00000000000000,
92 0.300000000000000 0.00000000000000 0.00000000000000,
SET-AXES-STR VOLUMES
@CLEAR
1 1 1 2
2 1 1 2
3 1 1 2
4 1 1 2
5 1 1 2
6 1 1 2
7 1 1 2
8 1 1 2
9 1 1 2
10 1 1 2
11 1 1 2
12 1 1 2
13 1 1 2
14 1 1 2
15 1 1 2
16 1 1 2
17 1 1 2
18 1 1 2
19 1 1 2
20 1 1 2
21 1 1 2
22 1 1 2
23 1 1 2
24 1 1 2
25 1 1 2
26 1 1 2
27 1 1 2
28 1 1 2
29 1 1 2
30 1 1 2
31 1 1 2
32 1 1 2
33 1 1 2
34 1 1 2
35 1 1 2
36 1 1 2
37 1 1 2
38 1 1 2
39 1 1 2
40 1 1 2
41 1 1 2
42 1 1 2
EGROUP THREEDSOLID NAME=1 DISPLACE=DEFAULT STRAINS=DEFAULT MATERIAL=1,
RSINT=DEFAULT TINT=DEFAULT RESULTS=STRESSES DEGEN=NO FORMULAT=0,
STRESSRE=GLOBAL INITIALS=BOTH FRACTUR=NO CMASS=DEFAULT,
STRAIN-F=1 UL-FORMU=DEFAULT LVUS1=0 LVUS2=0 SED=NO RUPTURE=ADINA,
INCOMPAT=DEFAULT TIME-OFF=0.00000000000000 POROUS=NO,
WTMC=1.00000000000000 OPTION=NONE DESCRIPT='NONE'
EGROUP THREEDSOLID NAME=2 DISPLACE=DEFAULT STRAINS=DEFAULT MATERIAL=2,
STRESSRE=GLOBAL INITIALS=NONE FRACTUR=NO CMASS=DEFAULT,
STRAIN-F=0 UL-FORMU=DEFAULT LVUS1=0 LVUS2=0 SED=NO RUPTURE=ADINA,
MATERIAL ELASTIC NAME=3 E=2.10000000000000E+10 NU=0.167000000000000,
DENSITY=2500.00000000000 ALPHA=0.00000000000000 MDESCRIP='NONE'
EGROUP SHELL NAME=3 DISPLACE=DEFAULT MATERIAL=3 RINT=DEFAULT,
SINT=DEFAULT TINT=2 RESULTS=STRESSES STRESSRE=GLOBAL PRINTVEC=0,
NLAYERS=1 INITIALS=NONE FAILURE=0 SECTION=0 CMASS=DEFAULT,
STRAINS=DEFAULT RUPTURE=ADINA TIME-OFF=0.00000000000000,
SUBDIVIDE VOLUME NAME=1 MODE=DIVISIONS NDIV1=3 NDIV2=3 NDIV3=3,
RATIO1=1.00000000000000 RATIO2=1.00000000000000,
RATIO3=1.00000000000000 PROGRESS=GEOMETRIC EXTEND=NONE CBIAS1=NO,
CBIAS2=NO CBIAS3=NO
@CLEAR
2
3
4
5
6
7
22
23
24
25
26
27
28
SUBDIVIDE VOLUME NAME=8 MODE=DIVISIONS NDIV1=3 NDIV2=3 NDIV3=3,
CBIAS2=NO CBIAS3=NO
@CLEAR
9
10
11
12
13
14
15
16
17
18
19
20
21
29
30
31
32
33
34
35
36
37
38
39
40
41
42
GVOLUME NODES=8 PATTERN=0 NCOINCID=BOUNDARIES NCFACE=123456 NCEDGE=,
'123456789ABC' NCVERTEX=12345678 NCTOLERA=1.00000000000000E-05,
SUBSTRUC=0 GROUP=1 MESHING=MAPPED PREFSHAP=AUTOMATIC,
DEGENERA=YES COLLAPSE=NO MIDNODES=CURVED METHOD=DELAUNAY,
BOUNDARY=ADVFRONT
@CLEAR
2
3
4
5
6
7
15
16
17
18
19
20
21
22
23
24
25
26
27
28
36
37
38
39
40
41
42
SUBSTRUC=0 GROUP=2 MESHING=MAPPED PREFSHAP=AUTOMATIC,
BOUNDARY=ADVFRONT
@CLEAR
8
9
10
11
12
13
14
29
30
31
32
33
34
35
GSURFACE NODES=4 PATTERN=AUTOMATIC NCOINCID=BOUNDARIES NCEDGE=1234,
NCVERTEX=1234 NCTOLERA=1.00000000000000E-05 SUBSTRUC=0 GROUP=3,
PREFSHAP=AUTOMATIC MESHING=MAPPED SMOOTHIN=NO DEGENERA=NO,
COLLAPSE=NO MIDNODES=CURVED METHOD=ADVFRONT FLIP=NO
@CLEAR
22
23
24
25
26
27
28
86
87
88
89
90
91
92
SURF-ELEMDAT SHELL
@CLEAR
22 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
0.00000000000000 'YES' 'NO' 0.00000000000000 0.00000000000000,
0.00000000000000 0.00000000000000 0.00000000000000,
23 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
24 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
25 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
26 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
27 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
28 0 0.00000000000000 'DEFAULT' 'DEFAULT' 16.1000000000000,
86 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
87 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
88 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
89 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
92 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
90 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
91 0 0.00000000000000 'DEFAULT' 'DEFAULT' 36.1000000000000,
VOL-ELEMDATA THREEDSOLID
@CLEAR
1 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
2 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
3 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
4 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
5 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
6 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
7 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 2.1000000000000 'NO' 0,
0
22 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
23 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
24 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
25 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
26 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
27 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
28 0 0 'DEFAULT' 'DEFAULT' 0.00000000000000 22.1000000000000 'NO' 0,
0
MASTER ANALYSIS=STATIC MODEX=EXECUTE TSTART=0.00000000000000 IDOF=111,
OVALIZAT=NONE FLUIDPOT=AUTOMATIC CYCLICPA=1 IPOSIT=STOP,
REACTION=YES INITIALS=NO FSINTERA=NO IRINT=DEFAULT CMASS=NO,
SHELLNDO=AUTOMATIC AUTOMATI=OFF SOLVER=SPARSE,
CONTACT-=CONSTRAINT-FUNCTION TRELEASE=0.00000000000000,
RESTART-=NO FRACTURE=NO LOAD-CAS=NO LOAD-PEN=NO MAXSOLME=0,
MTOTM=2 RECL=3000 SINGULAR=YES STIFFNES=1000.00000000000,
MAP-OUTP=NONE MAP-FORM=NO NODAL-DE='' POROUS-C=NO ADAPTIVE=0,
ZOOM-LAB=1 AXIS-CYC=0 PERIODIC=NO VECTOR-S=GEOMETRY EPSI-FIR=NO
TIMESTEP NAME=DEFAULT
@CLEAR
25 2.0000000000000
KINEMATICS DISPLACE=LARGE STRAINS=small UL-FORMU=ULH PRESSURE=NO,
INCOMPAT=NO
OVALIZAT=NONE FLUIDPOT=AUTOMATIC CYCLICPA=1 IPOSIT=CONTINUE,
PPROCESS NPROC=1 MINEL=0 MAXEL=999999
EGCONTROL MAXELG=999999
REACTION=YES INITIALS=DEF FSINTERA=NO IRINT=DEFAULT CMASS=NO,
CONTACT-=CONSTRAINT-FUNCTION TRELEASE=20.0000000000000,
ZOOM-LAB=1 AXIS-CYC=0 PERIODIC=NO VECTOR-S=GEOMETRY EPSI-FIR=NO |
