查看: 213|回复: 4
[流体] 流固耦合问题求助
发表于 2008-1-21 11:02:45 | 显示全部楼层 |阅读模式 来自 江苏南京
我在计算流固耦合中算到511步不能算了!!一共是800步。out file文件如下:请高手指教
*** ERROR *** CODE ADF3069:
    Unsuccessful during FSI iteration.
     *                                     E N D   O F   T I M E   I N T E G R A T I O N                                     *
     ADFSI VERSION 8.3.1   (BUILT ON 03-03-2006)
     FOR PROBLEM:  *** NO HEADING DEFINED ***
     LICENSED FROM   A D I N A  R & D  INC.
     *                                    S O L U T I O N   T I M E   L O G (IN SECONDS)                                     *
              TIME USED IN SOLID MODEL........................................................      363.34
              TIME USED IN FLUID MODEL........................................................      667.64
              TIME USED IN COUPLING COMPUTATION...............................................     1121.75
              T O T A L   S O L U T I O N   T I M E...........................................     2152.73
                                      S O L U T I O N   T I M E   I N   F L U I D
              TIME USED IN INPUT PHASE........................................................        1.21
              TIME USED IN ASSEMBLY...........................................................      565.25
              TIME USED IN SOLVER INITIATION..................................................        0.01
              TIME USED IN OUTPUT.............................................................       46.47
              TIME USED IN MESH HANDLING......................................................       54.71
              T O T A L  S O L U T I O N  T I M E  I N  F L U I D  M O D E L..................      667.64
1 110     510
发表于 2008-1-22 10:10:27 | 显示全部楼层 来自 湖北武汉
回复 1# 的帖子
This message indicates that the solution procedure in FSI iteration is
unsuccessful. You could find out more information from the
<fluid>.log and <solid>.log files. Check the stress and displacement
residual history. If they indicate a converging behavior, you may
increase the maximum number of FSI iterations and allow it to
converge. If they indicate a diverging behavior, considering the choices
below:
&#8226; Always check the solutions obtained so far to see if they are
physically reasonable. Try to exclude possibilities of errors in
input data.
&#8226; Reduce the displacement relaxation factor if it is not too small.
&#8226; It is generally suggested that tolerances in fluid and solid models
are smaller than the tolerance for FSI convergence tolerance. If
you have not done it, make some adjusts.
&#8226; Perform direct computing rather than the iterative computing.
It is also important to refer to the suggestions under the topics
“Model preparation and testing” and “Formulation of fluid-structure interactions”.
发表于 2008-10-14 14:17:27 | 显示全部楼层 来自 安徽合肥
这种每一个错误对应的详细解释应该在哪找呢
发表于 2008-10-14 14:21:52 | 显示全部楼层 来自 安徽合肥
那个所谓的流体理论手册是什么呢
发表于 2008-10-14 20:25:19 | 显示全部楼层 来自 四川乐山
程序的安装目录中的Docs子目录下面就有tmg-f_84.pdf
GMT+8, 2024-11-2 13:34 , Processed in 0.052802 second(s), 13 queries , Gzip On, MemCache On.
