- 9
- 2005-1-4
发表于 2008-5-30 21:49:57
来自 德国
There is no adams_plant.dll any more. Instead the s-function file is named adams_plant.mex32, don't worry about it, this file will work as the same.
After typing mex -setup and setting up the complier, there will be the following information:
Warning: The file extension of 32-bit Windows MEX-files was changed
from ".dll" to ".mexw32" in MATLAB 7.1 (R14SP3). The generated
MEX-file will not be found by MATLAB versions prior to 7.1.
Use the -output option with the ".dll" file extension to
generate a MEX-file that can be called in previous versions.
For more information see:
MATLAB 7.1 Release Notes, New File Extension for MEX-Files on Windows
To know more about this, please refer to 'Learning Adams/Controls with Control System Import > Step One – Setup MATLAB'
Good luck to you |
