查看: 130|回复: 2
[流体] 请教--关于模型unstable
发表于 2008-7-14 00:41:38 | 显示全部楼层 |阅读模式 来自 美国
最近老被一个问题困扰。在做纯流体的模型时,经常碰到如下类型的warning, 虽然模型可以运行,但结果不对。
哪位有这方面的经验,谢谢指点.
*** WARNING *** CODE ADF2006:
    Model may be unstable! Ratio 1.3170E+14 of largest to smallest diagonal
    elements in factorized coefficient matrix is greater than 1.E+11. The
    largest diagonal element 9.95679E+10 corresponds to
    y-velocity at node (label) 9288 and the smallest
    diagonal element 7.55968E-04 corresponds to pressure
    at node (label) 37579.
    When this ratio is too large, machine round-off errors may become so
    severe that stable models become unstable.
    Model may be unstable! Ratio 7.8769E+12 of largest to smallest diagonal
    largest diagonal element 6.59802E+10 corresponds to
    y-velocity at node (label) 51222 and the smallest
    diagonal element 8.37639E-03 corresponds to pressure
    at node (label) 40415.
firefiregu 该用户已被删除
发表于 2009-12-5 06:54:08 | 显示全部楼层 来自 德国
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-12-5 12:43:50 | 显示全部楼层 来自 北京
还要检查载荷,边界条件及模型初始条件的正确性。
GMT+8, 2024-11-2 07:36 , Processed in 0.031773 second(s), 13 queries , Gzip On, MemCache On.
