1• Always check the solutions obtained so far to see if they are
physically reasonable. Try to exclude possibilities of errors in
input data.
2• Reduce the stress relaxation factor if it is not too small.
3• Reduce the displacement relaxation factor if it is not too small.
4• It is generally suggested that tolerances in fluid and solid models
are smaller than the tolerance for FSI convergence tolerance. If
you have not done it, make some adjusts.
5• Perform direct computing rather than the iterative computing.
