查看: 93|回复: 2
[计算分析] 关于孔隙应力比如何确定的?
发表于 2008-12-4 09:11:35 | 显示全部楼层 |阅读模式 来自 江苏南京
对于Geoslope软件计算中关于孔隙应力比ru如何确定的?
土工原理与计算教材中说对于某土坡,ru已经确定,是如何计算的?画了水位线,还要计算这个值?
 楼主| 发表于 2008-12-4 09:14:23 | 显示全部楼层 来自 江苏南京
Ru Coefficients An ru value must be specified for each soil type.
The ru coefficient is defined as:
ru=u/γhi,
where:
γ the total unit weight of each soil strata in the slice
hi = the average thickness of each soil strata in the slice
i = the soil strata number
u = pore-water pressure
发表于 2008-12-4 11:30:00 | 显示全部楼层 来自 上海徐汇区
GMT+8, 2024-11-1 18:23 , Processed in 0.035203 second(s), 14 queries , Gzip On, MemCache On.
