- 2008-6-7
Luckyli,你好!有个问题先请教下:
我将中性文件mnf输入ASAMS中替换刚体零件,并做完仿真后推出ADAMS系统。然后再重新启动ADAMS,打开之前运行的柔体模型,发现有错误提示:说mnf文件找不到。需要在aview.pth文件中进行指定其路径。
这样的问题如何处理啊。。。。
错误信息为:
ERROR: The modal neutral file "E:/work-in-HUST/Projict-701-valve-system/ADAMS_Flex/10th_analyse_2_20090414_5_test_flex/file_inlet_6_e5.mnf" referenced by flexible body .MPRO_model.JINQIYAO_ANSYS_3_flex
was not found. Either the file is not in the proper location or the
location of the file is not specified in the aview.pth file. First,
examine your aview.pth file to see that it has an entry for .mnf files.
Next, make sure that the file exists at the path specified in the
aview.pth file.
恳请你能回复 |
