查看: 151|回复: 3
[结构] 血管内支架与血管壁的接触问题
发表于 2009-5-25 01:04:18 | 显示全部楼层 |阅读模式 来自 广东广州
大家好,请教一下接触的问题,上传了源文件,希望各位师兄师姐帮帮忙解决
本人在做一个“血管内支架与血管壁接触”的问题
由于支架比较复杂,用了42个volumn来建立,而血管虽然像一个pipe的四分之一,但是设置成由四个volumn 结合而成(主要想与后续问题结合起来)
所以在设置contact时就很麻烦了
支架是在内表面给力,本来不接触血管,然后在力的作用下撑开,最后把血管撑大一点,当然此时已经接触血管并且两者互相独立,不能有“陷入”的问题。
问题:
1、支架由很多体建成,所以设置contact surface时,系统不默认人眼所认为在支架外表面(即与血管接触那一面)的42个小面为一个统一体。所以我想把他们全都写在contact surface1里面时,系统警告这些面互相不是connected的。而实际上它们相连
所以我只能把它们当成一个个独立的surface来设置,请问这样可以吗?
2系统运行时出现以下问题,很着急
*** W A R N I N G ***
CONTACT GROUP NUMBER=
SOME CONTACT NODES BELONG TO MORE THAN ONE CONTACTOR SURFACE.
THIS MAY RESULT IN OVERCONSTRAINING ESPECIALLY WITH FRICTION.
MESH TOO DISTORTED (JACOBIAN DETERMINANT NOT POSITIVE)
*** S T O P ***
AUTOMATIC-LDC METHOD CANNOT CONVERGE IN THE FIRST STEP
RESTART WITH A SMALLER DISPLACEMENT IN THE AUTOMATIC-LDC:
I.E.
AUTOMATIC-LDC NOD=... DISPL=... DIR=...
INTERMEDIATE ITERATION RESULTS CAN BE OBTAINED BY
REQUESTING DETAILED ITERATION HISTORY PRINTOUT.
DIFFERENT SOLUTION STRATEGY MAY BE USED TO RERUN
THE ANALYSIS, SEE THE THEORY AND MODELING GUIDE.
***WARNING: Contactor node 2543 belongs to different contactor surfaces 6 and 5 in contact group 1
Contactor node 2555 belongs to different contactor surfaces 6 and 5 in contact group 1
Contactor node 2539 belongs to different contactor surfaces 6 and 5 in contact group 1
Contactor node 2849 belongs to different contactor surfaces 8 and 7 in contact group 1
Contactor node 2861 belongs to different contactor surfaces 8 and 7 in contact group 1
Contactor node 2845 belongs to different contactor surfaces 8 and 7 in contact group 1
Contactor node 2512 belongs to different contactor surfaces 13 and 4 in contact group 1
Contactor node 2637 belongs to different contactor surfaces 13 and 10 in contact group 1
Contactor node 2540 belongs to different contactor surfaces 14 and 5 in contact group 1
Contactor node 2636 belongs to different contactor surfaces 14 and 10 in contact group 1
Contactor node 2827 belongs to different contactor surfaces 15 and 6 in contact group 1
Contactor node 2934 belongs to different contactor surfaces 15 and 11 in contact group 1
Contactor node 2846 belongs to different contactor surfaces 16 and 7 in contact group 1
Contactor node 2933 belongs to different contactor surfaces 16 and 11 in contact group 1
Contactor node 3124 belongs to different contactor surfaces 17 and 8 in contact group 1
Contactor node 3231 belongs to different contactor surfaces 17 and 12 in contact group 1
Contactor node 3143 belongs to different contactor surfaces 18 and 9 in contact group 1
Contactor node 3230 belongs to different contactor surfaces 18 and 12 in contact group 1
Contactor node 2570 belongs to different contactor surfaces 19 and 13 in contact group 1
Contactor node 2598 belongs to different contactor surfaces 20 and 14 in contact group 1
Contactor node 2874 belongs to different contactor surfaces 21 and 15 in contact group 1
Contactor node 2597 belongs to different contactor surfaces 21 and 20 in contact group 1
Contactor node 2609 belongs to different contactor surfaces 21 and 20 in contact group 1
Contactor node 2593 belongs to different contactor surfaces 21 and 20 in contact group 1
Contactor node 2895 belongs to different contactor surfaces 22 and 16 in contact group 1
Contactor node 3171 belongs to different contactor surfaces 23 and 17 in contact group 1
Contactor node 2894 belongs to different contactor surfaces 23 and 22 in contact group 1
Contactor node 2906 belongs to different contactor surfaces 23 and 22 in contact group 1
Contactor node 2890 belongs to different contactor surfaces 23 and 22 in contact group 1
Contactor node 3192 belongs to different contactor surfaces 24 and 18 in contact group 1
Contactor node 2576 belongs to different contactor surfaces 25 and 19 in contact group 1
Contactor node 2571 belongs to different contactor surfaces 25 and 19 in contact group 1
Contactor node 2665 belongs to different contactor surfaces 26 and 13 in contact group 1
Contactor node 2677 belongs to different contactor surfaces 26 and 13 in contact group 1
Contactor node 3528 belongs to different contactor surfaces 27 and 26 in contact group 1
Contactor node 2767 belongs to different contactor surfaces 28 and 14 in contact group 1
Contactor node 2755 belongs to different contactor surfaces 28 and 14 in contact group 1
Contactor node 3527 belongs to different contactor surfaces 28 and 27 in contact group 1
Contactor node 2603 belongs to different contactor surfaces 29 and 20 in contact group 1
Contactor node 2878 belongs to different contactor surfaces 30 and 21 in contact group 1
Contactor node 3439 belongs to different contactor surfaces 30 and 29 in contact group 1
Contactor node 3447 belongs to different contactor surfaces 30 and 29 in contact group 1
Contactor node 2962 belongs to different contactor surfaces 31 and 15 in contact group 1
Contactor node 2974 belongs to different contactor surfaces 31 and 15 in contact group 1
Contactor node 3798 belongs to different contactor surfaces 32 and 31 in contact group 1
Contactor node 3064 belongs to different contactor surfaces 33 and 16 in contact group 1
Contactor node 3052 belongs to different contactor surfaces 33 and 16 in contact group 1
Contactor node 3797 belongs to different contactor surfaces 33 and 32 in contact group 1
Contactor node 2900 belongs to different contactor surfaces 34 and 22 in contact group 1
Contactor node 3175 belongs to different contactor surfaces 35 and 23 in contact group 1
Message limit reached - 22 messages has been suppressed.
 楼主| 发表于 2009-5-25 01:06:25 | 显示全部楼层 来自 广东广州
希望大家帮忙一下,我用这个软件来做毕业设计,只有短短的两个月时间,所以没能好好地搞懂其中的设置等问题。谢谢。
现在我面临只有5天时间要完成它的问题,希望大家帮帮忙
恳求
发表于 2009-5-25 11:08:33 | 显示全部楼层 来自 湖北武汉
支架有限元模型网格划分有问题,是不连续的
而且单位分的太粗,至少得保证厚度有3个单元。
 楼主| 发表于 2009-5-25 18:19:48 | 显示全部楼层 来自 广东广州
由于老是出现 element too distorted, Jacobian determination not positive的警告,我觉得mesh是很头疼的事情,好像必须两个物件用一样的mesh尺寸和方式才行,然后我就把它们分得很疏,是否单元就不会扭曲?
还有对于contact surfaces的设置,也是不知道如何确定。例如,我把支架设置成rigid钢体面后,还能不能通过给内表面力,让它变形呢?
希望大家帮帮忙解答,非常感谢!!!
GMT+8, 2024-11-2 09:33 , Processed in 0.033836 second(s), 12 queries , Gzip On, MemCache On.
