查看: 173|回复: 4
[模型数据转换] 用ansys生成.mnf模态文件到Adams时出错
发表于 2009-6-25 20:03:47 | 显示全部楼层 |阅读模式 来自 山东淄博
如题,错误提示如下:有很多这样的warning,最后一个error,然后ansys自动exit,求高手帮忙看看!
*** WARNING ***   SUPPRESSED MESSAGE    CP =     125.844   TIME= 19:51:25
Term 1 (node 251684 ROTX) on CE number 190 is not active on any element
  This CE is ignored.
Term 1 (node 251684 ROTY) on CE number 191 is not active on any element
  This CE is ignored.
Term 1 (node 251684 ROTZ) on CE number 192 is not active on any element
  This CE is ignored.
*** WARNING ***   SUPPRESSED MESSAGE    CP =     125.922   TIME= 19:51:25
The first term of CE number=4 has no active DOF associated with it.
This CE is ignored.
*** ERROR ***     SUPPRESSED MESSAGE    CP =     125.922   TIME= 19:51:25
An illegal case involving constraint equations in a substructuring
analysis has been detected.  Any master DOF in a substructure analysis
cannot be the first DOF in a constraint equation.
发表于 2009-6-26 17:24:10 | 显示全部楼层 来自 北京
ANSYS不会用啊:(
 楼主| 发表于 2009-6-30 15:15:09 | 显示全部楼层 来自 山东淄博
就没有高手吗?
发表于 2013-7-3 21:13:05 | 显示全部楼层 来自 广东广州
我也遇到这样的问题
发表于 2013-8-20 18:53:29 | 显示全部楼层 来自 辽宁锦州
没有解答
GMT+8, 2024-11-2 15:17 , Processed in 0.042211 second(s), 13 queries , Gzip On, MemCache On.
