查看: 71|回复: 3
[前后处理] 请问这是什么问题?
发表于 2009-7-16 20:22:54 | 显示全部楼层 |阅读模式 来自 北京
F:\pipe\s-a-r.dat + F:\pipe\f-a-r.dat Using Network floating license. Floating License Server = localhost Starting Job on Thu Jul 16 20:23:22 2009 Checking prerequisite files... Maximum memory specified for solution = 857.3 mb Initializing ... Stage 1 Initializing ... Stage 2 Allocated 857.3 MB memory. Starting Solution Process ... Computation starts ... Input phase... Assemblage of linear matrices. Calculate and store the load vector ENDCODE=1 *** Program stopped abnormally *** *** Please see the *.out file for details *** Error encountered ... Releasing floating license. Job Canceled on Thu Jul 16 20:23:23 2009
是不是记忆的问题?谢谢
 楼主| 发表于 2009-7-16 20:29:26 | 显示全部楼层 来自 北京
Starting Job on Thu Jul 16 20:16:52 2009
Maximum memory specified for solution = 1681.6 mb
Unable to allocate specified memory
Attempting to allocate lesser memory
Allocated 1381.6 MB memory.
Input phase...
ENDCODE=1
Job Canceled on Thu Jul 16 20:16:52 2009
 楼主| 发表于 2009-7-16 20:29:55 | 显示全部楼层 来自 北京
谢谢帮忙,如何处理?
发表于 2009-7-17 11:42:10 | 显示全部楼层 来自 安徽合肥
3# marsdb707
老大你别总发这样的问题,看你发了几个类似的了。建议自己多试一下,多看手册,多看以前的帖子。
这个报告不是说了,让你看.out文件 for details,“*** Please see the *.out file for details ***”,里面没给有error的描述的话,再看 A.log与F.log,一般都有的
2
GMT+8, 2024-11-2 09:22 , Processed in 0.029300 second(s), 12 queries , Gzip On, MemCache On.
