查看: 70|回复: 0
[前后处理] 动力计算最好怎么提示是这样的?
发表于 2009-11-21 15:13:34 | 显示全部楼层 |阅读模式 来自 大连理工大学
动力计算最好怎么提示是这样的? 说的是最后一步被修改了,那结果会准确吗?
***WARNING: The last nodal saving timestep block has
             been modified so that the last solution
             timestep is referenced.
             The last element saving timestep block
             has been modified so that the last
             solution timestep is referenced.
GMT+8, 2024-11-2 07:30 , Processed in 0.027261 second(s), 11 queries , Gzip On, MemCache On.
