查看: 113|回复: 1
[流体] 流固耦合,请教版主,各位高手,弹簧单元怎么用呀?
发表于 2009-11-25 14:36:40 | 显示全部楼层 |阅读模式 来自 大连理工大学
版主:
       我用势流体做流固耦合,为了得到上下流动的自由表面,在上表面个点上(points不是nodes)上加弹簧单元,可是怎么会有这么多错误呢?怎么回事儿呢?
救救我吧!
                  *** STIFFNESS MATRIX NOT POSITIVE DEFINITE ***
NODE=        24 EQUATION=        49  DOF= FLUID POTENT.  PIVOT= -2.19406530E+04
NODE=       394 EQUATION=       759  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       456 EQUATION=       761  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       458 EQUATION=       763  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       460 EQUATION=       765  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       462 EQUATION=       767  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       464 EQUATION=       769  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       466 EQUATION=       771  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       468 EQUATION=       773  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       470 EQUATION=       775  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
NODE=       472 EQUATION=       777  DOF= Y-TRANSLATION  PIVOT=  0.00000000E+00
*** IN SMALL DISPLACEMENT LINEAR ELASTIC ANALYSIS ***
     CHECK THE FOLLOWING --
(A) BOUNDARY CONDITIONS -
          THE B.C. MUST NOT ADMIT A RIGID BODY
          DISPLACEMENT OR ROTATION OF THE TOTAL
          STRUCTURE.
(B) DELETION OF DEGREES-OF-FREEDOM -
          ALL D.O.F. AT NODAL POINTS WITHOUT
          STIFFNESS CONTRIBUTIONS FROM ELEMENTS
          MUST HAVE BEEN DELETED.
(C) ELEMENT GEOMETRY AND CONNECTIVITY -
          ALL ELEMENTS MUST HAVE BEEN INPUT WITH
          PROPER NODAL NUMBERS, AS DESCRIBED IN
          THE USERS MANUAL.
(D) ELEMENT INTEGRATION ORDERS -
          THE ORDERS OF NUMERICAL INTEGRATIONS FOR
          EVALUATION OF ELEMENT MATRICES MUST BE
          SUFFICIENTLY HIGH.
(E) MATERIAL DATA -
          ALL MATERIAL DATA MUST BE PHYSICALLY
          REASONABLE (E.G. YOUNG*S MODULUS MUST
          BE GREATER THAN ZERO).
*** IN MATERIALLY NONLINEAR AND/OR LARGE DISPLACEMENT  ANALYSIS ***
     IF THE MODEL HAS BEEN INPUT CORRECTLY (WITH ALL
     THE ABOVE CONSIDERATIONS TAKEN INTO ACCOUNT), THEN
     THE COLLAPSE LOAD OF THE MODEL HAS BEEN REACHED.
发表于 2009-11-25 20:34:16 | 显示全部楼层 来自 北京
GMT+8, 2024-11-2 07:28 , Processed in 0.026591 second(s), 10 queries , Gzip On, MemCache On.
