查看: 124|回复: 1
[多场耦合] FSI求解遇到困难
发表于 2009-11-28 19:34:14 | 显示全部楼层 |阅读模式 来自 江苏扬州
* WARNING *** CODE ADF8000:
Element is found overlapped in <HTOHDH>
*** WARNING *** CODE ADF8000:
*** ERROR *** CODE ADF5010:
    The following element is overlapped:
       element (label)      =       3580;
       element group number =          1;
       local nodal indices and their coordinates =
         1  0.00000000E+00 -0.81319056E+00  0.43366809E+00
         2  0.00000000E+00 -0.79037922E+00  0.44428033E+00
         3  0.00000000E+00 -0.81075674E+00  0.43432885E+00
如何解决这个问题呢?
发表于 2009-11-28 20:36:29 | 显示全部楼层 来自 湖北武汉
计算时单元扭曲!检查网格质量,或者减小时间步长!!
GMT+8, 2024-11-2 07:20 , Processed in 0.032433 second(s), 13 queries , Gzip On, MemCache On.
