查看: 191|回复: 2
[多场耦合] 波浪模拟问题
发表于 2009-11-29 09:40:05 | 显示全部楼层 |阅读模式 来自 江苏扬州
*** ERROR *** CODE ADF2702:
    Fluid node (label) 6111 is not attached to solid fluid-structure
    interface 1. The relative distance to solid boundary element
    90 is 1.14E+00.
    The fluid nodal coordinates are (0.00E+00, 5.14E-05, 5.72E-01)
    The points and their coordinates of the solid boundary element are:
        point      68 = ( 0.000E+00, 6.396E-05, 5.621E-01)
        point      67 = ( 0.000E+00, 5.812E-05, 5.669E-01)
    Possible causes are:
      * Fluid-structure interfaces in fluid and solid models are not
        coincident;
      * Solid boundary elements are too coarse compared with fluid boundary
        elements on the same fluid-structure interface.
发表于 2009-11-29 16:25:27 | 显示全部楼层 来自 北京
原因不是都已经说明白了吗
发表于 2010-5-9 21:49:22 | 显示全部楼层 来自 重庆
导致这个问题的原因还是比较多的!贴出IN文件吧
GMT+8, 2024-11-2 05:39 , Processed in 0.026812 second(s), 10 queries , Gzip On, MemCache On.
