查看: 335|回复: 4
[ADAMS CAR, Chassis, Engine] adams car整车装配通讯器问题
发表于 2010-10-10 13:42:18 | 显示全部楼层 |阅读模式 来自 北京信息科技大学
我的assembly打开后提示信息如下
有好多通讯器没匹配上啊
Opening the assembly: 'aa'...
Opening the front suspension subsystem: 'front_susp'...
Opening the front steering subsystem: 'steering'...
Opening the front wheel subsystem: 'front_tires'...
Opening the rear wheel subsystem: 'rear_tires'...
Opening the body subsystem: 'body'...
Opening the brake_system subsystem: 'brakes'...
Opening the rear suspension subsystem: 'rear_susp'...
Assembling subsystems...
Assigning communicators...
WARNING: The following input communicators were not assigned during assembly:
     testrig.cis_engine_rpm
     testrig.cis_engine_speed
     testrig.cis_max_gears
     testrig.cis_diff_ratio
     testrig.cis_max_throttle
     testrig.cis_downforce_coefficient
     testrig.cis_crankshaft_ratio
     testrig.cis_transmission_efficiency
     testrig.cis_drive_torque_bias_front
     testrig.cis_max_engine_speed
     testrig.cis_engine_revlimit_rpm
     testrig.cis_min_engine_speed
     testrig.cis_engine_idle_rpm
     testrig.cis_transmission_spline
     testrig.cis_engine_map
     testrig.cis_transmission_input_omega
     testrig.cis_clutch_displacement_ic
     testrig.cis_max_engine_driving_torque
     testrig.cis_max_engine_braking_torque
     front_susp.cil_swing_to_body (attached to ground)
     front_susp.cir_swing_to_body (attached to ground)
     rear_susp.cil_tripot_to_differential (attached to ground)
     rear_susp.cir_tripot_to_differential (attached to ground)
Assignment of communicators completed.
Assembly of subsystems completed.
Full vehicle assembly ready.
 楼主| 发表于 2010-10-10 13:44:46 | 显示全部楼层 来自 北京信息科技大学
我的模型是错误的  不能进行仿真
下面是软件自带模型打开后的消息
为什么我的有那么多不匹配 的通讯器呢
我每个子系统也没有少啊
Opening the assembly: 'MDI_Demo_Vehicle'...
Opening the front suspension subsystem: 'TR_Front_Suspension'...
Opening the rear suspension subsystem: 'TR_Rear_Suspension'...
Opening the front steering subsystem: 'TR_Steering'...
Opening the front wheel subsystem: 'TR_Front_Tires'...
Opening the rear wheel subsystem: 'TR_Rear_Tires'...
Opening the body subsystem: 'TR_Body'...
Opening the rear powertrain subsystem: 'TR_Powertrain'...
Opening the brake_system subsystem: 'TR_Brake_System'...
     TR_Front_Suspension.cil_ARB_pickup
     TR_Front_Suspension.cir_ARB_pickup
     TR_Front_Suspension.cil_tripot_to_differential (attached to ground)
     TR_Front_Suspension.cir_tripot_to_differential (attached to ground)
     TR_Rear_Suspension.cil_ARB_pickup
     TR_Rear_Suspension.cir_ARB_pickup
发表于 2011-5-23 14:30:02 | 显示全部楼层 来自 北京丰台
你再检查一下你建立的模板中通讯器的名称和角色是否与其他子系统相匹配
发表于 2011-7-15 21:55:54 | 显示全部楼层 来自 四川成都
这也是我一直弄不参透的
发表于 2014-4-4 18:53:14 | 显示全部楼层 来自 浙江杭州
请问楼主现在通讯器的问题解决了吗
GMT+8, 2024-11-2 11:36 , Processed in 0.050391 second(s), 13 queries , Gzip On, MemCache On.
