查看: 297|回复: 8
[用户自编子程序] ADAMS 宏命令建凸轮
发表于 2011-3-24 18:13:03 | 显示全部楼层 |阅读模式 来自 辽宁沈阳
下边的程序是一本书上的宏命令,用来建凸轮的,但我在ADAMS中使用的时候出错,我也不知道错哪。
哪位大侠帮忙看看,小弟会感激的内牛满面!
程序:
!$A:T=real: D=72
!$B:T=real: D=0
!$C:T=real: D=144
!$D:T=real: D=100
!$E:T=real: D=216
!$F:T=real: D=-100
!$G:T=real: D=360
!$H:T=real: D=0
!$Ref_Marker_name:T=marker
!$Ref_Part_name:T=part
!$Base_Circle:T=integer: D=100
!$Cam_TYPE:T=list(step,step5):U=step
!$L:T=real: D=10
var cre var=xxx integer_value=1
while cond=(eval(DB_EXISTS("CAM_MATRIX_"//xxx)))
var mod var=xxx integer_value=(eval(xxx+1))
end
IF CONDITION= ("$Cam_TYPE"=="step")
! Full Matrix
  data_element create matrix full&
  matrix_name = (eval("CAM_MATRIX_"//xxx))&
  comments=""&
  row_count = (COLS(Series(0,1,360)))&
column_count=3 &
values = (STACK(STACK(COS(Series(0,1,360))*($Base_Circle+&
Step(Series(0,1,360),0,0,$A,$B)+&
Step(Series(0,1,360),$A,0,$C,$D)+Step(Series(0,1,360),$C,0,$E,$F)+&
Step(Series(0,1,360),$E,0,$G,$H)),SIN(Series(0,1,360))*&
($Base_Circle+Step(Series(0,1,360),0,0,$A,$B)+&
Step(Series(0,1,360),$E,0,$G,$H))),0*Series(0,1,360)))&
input_order = by_column&
units = length
ELSEIF CONDITION=("$Cam_TYPE"=="Step5")
!  Full Matrix
   matrix_name=(eval("CAM_MATRIX_"//xxx))&
   comments="" &
   row_count=(COLS(Series(0,1,360)))&
   column_count=3&
values=(Stack(Stack((COS(Series(0,1,360))*($Base_Circle+&
APPEND(APPEND(APPEND($B*(10*Series2(0,1,$A)**3&
-15*Series2(0,1,$A)**4+6*Series2(0,1,$A)**5),$B+&
$D*(10*Series2(0,1,($C-$A))**3-15*Series2(0,1,($C-$A))**4+&
6*Series2(0,1,($C-$A))**5)),$B+$D+&
$F*(10*Series2(0,1,($E-$C))**3-15*Series2(0,1,($E-$C))**4+&
6*Series2(0,1,($E-$C))**5)),$B+$D+$F+&
$H*(10*Series2(0,1,($G-$E))**3-15*Series2(0,1,($G-$E))**4+&
6*Series2(0,1,($G-$E))**5)),&
(SIN(Series(0,1,360))*($Base_Circle+&
APPEND(APPEND(APPEND($B*(10*Series2(0,1,$A)**3-15*Series2(0,1,$A)**4+&
6*Series2(0,1,$A)**5),$B+$D*(10*Series2(0,1,($C-$A))**3-
&15*Series2(0,1,($C-$A))**4+6*Series2(0,1,($C-$A))**5)),&
$B+$D+$F*(10*Series2(0,1,($E-$C))**3-15*Series2(0,1,($E-$C))**4+&
6*Series2(0,1,($G-$E))**5))))),Series(0,1,360)*0))&
input_order=by_column&
units=length
end
data_element create curve&
curve_name = (eval("CAM_CURVE_"//xxx))&
closed=yes&
fit_type = curve_points&
geomety create curve bspline&
   bspline_name = (eval("$Ref_Part_name.GCURVE_"//xxx))&
   ref_curve_name = (eval("CAM_CURVE_"//xxx))&
   ref_marker_name = $Ref_Marker_name&
   segment_count = 360
geometry create shape extrusion&
   extrusion_name = (eval("$Ref_Part_name.EXTRUSION_"//xxx))&
   reference_marker = $Ref_Marker_name&
   profile_curve = (eval("$Ref_Part_name.GCURVE_"//xxx))&
   length_along_z_axis = $L
var del var=xxx
错误:
ERROR:   ---------------------------------------------------------------------
ERROR:   Error detected on line number 28, character 10 of the macro '.MACRO_1'.
ERROR:   Invalid return. Terminate this expressions with a closing parenthesis.
ERROR:   The command was not executed.
ERROR:   +1&> values = (STACK(STACK(COS(Series(0,1,360))*(100+&
ERROR:   Error detected on line number 29, character 36 of the macro '.MACRO_1'.
ERROR:   'Step(Series(0,1,360),0,0,72.0,0.0)+&' is not a valid keyword. You may have misspelled
ERROR:  the keyword or you may be missing a continuation character(&)
ERROR:  on the previous line.
ERROR:   +1>> Step(Series(0,1,360),0,0,72.0,0.0)+&
ERROR:   Error detected on line number 30, character 85 of the macro '.MACRO_1'.
ERROR:   'Step(Series(0,1,360),72.0,0,144.0,100.0)+Step(Series(0,1,360),144.0,0,216.0,-100.0)+&' is not a valid keyword. You may have misspelled
ERROR:   +1>> Step(Series(0,1,360),72.0,0,144.0,100.0)+Step(Series(0,1,360),144.0,0,216.0,-100.0)+&
ERROR:   Error detected on line number 31, character 63 of the macro '.MACRO_1'.
ERROR:   'Step(Series(0,1,360),216.0,0,360.0,0.0)),SIN(Series(0,1,360))*&' is not a valid keyword. You may have misspelled
ERROR:   +1>> Step(Series(0,1,360),216.0,0,360.0,0.0)),SIN(Series(0,1,360))*&
ERROR:   Error detected on line number 32, character 1 of the macro '.MACRO_1'.
ERROR:   +1>> (100+Step(Series(0,1,360),0,0,72.0,0.0)+&
ERROR:   Error detected on line number 33, character 85 of the macro '.MACRO_1'.
ERROR:   Error detected on line number 34, character 62 of the macro '.MACRO_1'.
ERROR:   'Step(Series(0,1,360),216.0,0,360.0,0.0))),0*Series(0,1,360)))&' is not a valid keyword. You may have misspelled
ERROR:   +1>> Step(Series(0,1,360),216.0,0,360.0,0.0))),0*Series(0,1,360)))&
ERROR:   Error detected on line number 35, character 14 of the macro '.MACRO_1'.
ERROR:   'input_order' is not a valid entity.
ERROR:   +1>>  input_order = by_column&
ERROR:   Error detected on line number 69, character 41 of the macro '.MACRO_1'.
ERROR:    Database object "CAM_MATRIX_1" does not exist
ERROR:   &> matrix_name = (eval("CAM_MATRIX_"//xxx))&
ERROR:   Error detected on line number 79, character 58 of the macro '.MACRO_1'.
ERROR:    Database object ".model_1.PART_2.GCURVE_1" does not exist
ERROR:   &>    profile_curve = (eval(".model_1.PART_2.GCURVE_"//xxx))&
发表于 2011-3-24 21:30:32 | 显示全部楼层 来自 黑龙江哈尔滨
楼主指令运用的相当犀利,很佩服
 楼主| 发表于 2011-3-25 08:52:47 | 显示全部楼层 来自 辽宁沈阳
这是一本书上的!输上去一运行老错!
 楼主| 发表于 2011-3-25 08:53:07 | 显示全部楼层 来自 辽宁沈阳
2# coscos163
这是一本书上的!输上去一运行老错!
 楼主| 发表于 2011-3-25 15:25:15 | 显示全部楼层 来自 辽宁沈阳
发表于 2013-7-31 20:02:07 | 显示全部楼层 来自 广东
楼主你的问题解决了吗? 求书名,
发表于 2015-1-10 21:44:20 | 显示全部楼层 来自 北京
请问是哪本书上的?
发表于 2015-5-25 17:09:02 | 显示全部楼层 来自 安徽合肥
求书名  我也在学二次开发呢
发表于 2015-6-4 15:05:37 | 显示全部楼层 来自 陕西西安
学习了!求书名
GMT+8, 2024-11-2 03:31 , Processed in 0.039990 second(s), 14 queries , Gzip On, MemCache On.
