查看: 135|回复: 3
[结构] adina是否含有超弹的壳单元?如基于neo-hookean的壳。
发表于 2011-7-14 06:19:09 | 显示全部楼层 |阅读模式 来自 美国
悬赏100仿真币已解决
这里人气旺,高手多,过来请教一下。
如果有的话,能麻烦将软件自带的参考文档贴一下吗?
或者是相关的文章也行。
谢谢。
最佳答案
查看完整内容
Here are the papers. http://web.mit.edu/kjb/www/Publications_Prior_to_1998/A_Hyperelastic-Based_Large_Strain_Elasto-Plastic_Constitutive_Formulation_with_Combined_Isotropic-Kinematic_Hardening_using_the_Logarithmic_Stress_and_Strain_Measures.pdf http://web.mit.edu/kjb/www/Publications_Prior_to_1998/A_Finite_Element_Formulation_for_Nonlinear_Incompressible_Elastic_and_Inelastic_Analysis.pdf htt ...
发表于 2011-7-14 06:19:10 | 显示全部楼层 来自 美国
回复
发表于 2011-7-14 07:24:12 | 显示全部楼层 来自 美国
1# caoer
Adina should have it as you can see from the attached figures. The manual you can find anywhere on web.
I also suggest you buy a copy of Adina and you can renew each year without pay as long as you are student. If you are the first-time buyer, you also get Bathe's book for free.
http://www.adina.com/n900.shtml
回复
 楼主| 发表于 2011-7-14 10:41:14 | 显示全部楼层 来自 美国
thank, tonny.
Looks the Adina is able to model the hyperelastic shell.
does the Adina help document say sth more about it.
for instance, the reference books, papers.
I would know how difficult to code it up. If it is time-consuming, I may switch my way.
THanks!
回复
GMT+8, 2024-11-2 01:26 , Processed in 0.029243 second(s), 11 queries , Gzip On, MemCache On.
