查看: 289|回复: 4
[ADAMS CAR, Chassis, Engine] adamscar组装时,通讯器信息如下,不知道是哪里不对
发表于 2011-8-15 19:24:34 | 显示全部楼层 |阅读模式 来自 广东广州
Creating the full vehicle assembly: 'scheliang'...
Opening the front suspension subsystem: 'front_suspension'...
Opening the rear suspension subsystem: 'rear_suspension'...
Opening the front steering subsystem: 'steering'...
Opening the front wheel subsystem: 'fronttire'...
Opening the rear wheel subsystem: 'reartire'...
Opening the body subsystem: 'Body'...
Opening the rear powertrain subsystem: 'Powertrain_lt'...
Opening the brake_system subsystem: 'brake'...
Assembling subsystems...
Assigning communicators...
WARNING: The following input communicators were not assigned during assembly:
     testrig.cis_downforce_coefficient
     testrig.cis_crankshaft_ratio
     testrig.cis_transmission_efficiency
     testrig.cis_drive_torque_bias_front
     front_suspension.cil_ARB_pickup
     front_suspension.cir_ARB_pickup
     front_suspension.cil_tripot_to_differential (attached to ground)
     front_suspension.cir_tripot_to_differential (attached to ground)
     rear_suspension.cil_ARB_pickup
     rear_suspension.cir_ARB_pickup
Assignment of communicators completed.
Assembly of subsystems completed.
Full vehicle assembly ready.
 楼主| 发表于 2011-8-16 09:31:52 | 显示全部楼层 来自 广东广州
无呜呜呜呜,都没有人
发表于 2011-8-28 13:16:00 | 显示全部楼层 来自 安徽合肥
laienming 发表于 2011-8-16 09:31
无呜呜呜呜,都没有人
我来回复吧!!嘻嘻在进行整车组装时!!你不能看到有attached to ground !不然这个就链接到地面了,你的发动机里少这个tripot_to_differential output 还是你的前悬模板里少这个的input 一个是mount 一个是location!!
发表于 2011-8-28 13:17:15 | 显示全部楼层 来自 安徽合肥
lxm6116699 发表于 2011-8-28 13:16
我来回复吧!!嘻嘻在进行整车组装时!!你不能看到有attached to ground !不然这个就链接到地面了,你的 ...
查一下这两个模板里的通讯器!!应该是你的前悬少个动力输出的位置input通讯器!!
发表于 2014-4-4 19:01:14 | 显示全部楼层 来自 浙江杭州
请问谁有通讯器的教程吗,可否传一份给我,谢谢了623147806@qq.com
GMT+8, 2024-11-2 11:40 , Processed in 0.026604 second(s), 10 queries , Gzip On, MemCache On.
